Author Topic: Hard line wear?  (Read 8282 times)
May 23, 2013, 05:13:10 pm
wolf_walker
  • 1205
Hard line wear?
« on: May 23, 2013, 05:13:10 pm »
Anyone ever seen wear on the ID of the injector hard lines? Pump and injector side, looks vaguely like a torx socket.
Is not any sort of deposit.
These lines probably have a half mil on em if they are the set I think they are.
Wonder if that much fuel wore em?
Sent from my SCH-I535 using Tapatalk 2
Mentat Text Two
Reply #1May 25, 2013, 08:14:58 pm
damac
  • 531
Re: Hard line wear?
« Reply #1 on: May 25, 2013, 08:14:58 pm »
Maybe I have been lucky, but I have never had an issue with one hard line on the handfull of cars I have had over the past few years as daily drivers.  I just make sure to release all hard lines when timing and use the vibration dampners then tighten everything down.
1985 turbo diesel jetta
Reply #2May 25, 2013, 08:49:55 pm
Re: Hard line wear?
« Reply #2 on: May 25, 2013, 08:49:55 pm »
I once had a pinhole on one line... damn near invisible, but it was spraying aerosol diesel all over the engine bay. Seemed to be a void, the rest of the line was fine, so I flowed some bronze onto it and put it back in service.
Reply #3May 25, 2013, 09:07:41 pm
wolf_walker
  • 1205
Re: Hard line wear?
« Reply #3 on: May 25, 2013, 09:07:41 pm »
Yeah I've seen a few leak/crack but never noticed anything odd on the inlet/outlet.
Weird..
Mentat Text Two
Reply #4May 27, 2013, 07:46:49 am
rs899
  • 647
Re: Hard line wear?
« Reply #4 on: May 27, 2013, 07:46:49 am »
I have had some crack over the years and the lines leak at the fittings from wear and age.
Prothe has a set for $14 that I have been running for 2 years with no issues so far.
Reply #5May 27, 2013, 12:37:39 pm
wolf_walker
  • 1205
Re: Hard line wear?
« Reply #5 on: May 27, 2013, 12:37:39 pm »
Might just buy some cheap as they are.
Mentat Text Two
Reply #6June 03, 2013, 01:27:08 pm
tyb525
  • 183
Re: Hard line wear?
« Reply #6 on: June 03, 2013, 01:27:08 pm »
I would advise against going cheap, I bought a cheap chinese one from ebay to replace a an old cracked original one. The new one cracked a week later in a different spot, with the anti-vib clips on. So I ponied up and bought a new set made in germany I think, and they've got probably 10k on them so far.
2004 Golf BEW, '81 1.6 NA rabbit (soon to be parted out)
Reply #7June 03, 2013, 03:57:04 pm
Turftech
  • 113
Re: Hard line wear?
« Reply #7 on: June 03, 2013, 03:57:04 pm »
I second the Prothe lines. Mine are still going strong after 200 k.
'90 Jetta GL TD  570'000 Kms and counting (Gave her to a friend)
'92 Passat G60 Syncro Wagon 180'000kms. TDI conversion project
'87 Jetta Coupe 325'000kms. MF IDI conversion project
Reply #8June 03, 2013, 05:04:02 pm
wolf_walker
  • 1205
Re: Hard line wear?
« Reply #8 on: June 03, 2013, 05:04:02 pm »
Not that I don't believe they could be crap, but I'd think it'd be hard at this late date to not be able to make a steel
line like that.
Mentat Text Two
Reply #9June 03, 2013, 08:47:59 pm
tyb525
  • 183
Re: Hard line wear?
« Reply #9 on: June 03, 2013, 08:47:59 pm »
That's what I thought too when I bought it, how could they screw it up?
Reply #10June 03, 2013, 10:50:01 pm
Re: Hard line wear?
« Reply #10 on: June 03, 2013, 10:50:01 pm »
EAsy, you use a cheaper materiel til somebody calls you on it.
Or there is a misunderstanding of a blueprint.... we got a couple  prototype bikes from a Taiwanese factory, and the steel one rode well.  the aluminum one in high gear, the crankset would bend 3-4" side to side opposite your downward pedal stroke.  After a few emails, we fond out both bikes had been assembled using the  steel tubing thickness spec , so it was about 1/3 as strong as it should have been.
Reply #11June 04, 2013, 04:50:52 am
Re: Hard line wear?
« Reply #11 on: June 04, 2013, 04:50:52 am »
I see this very often. Probably 75% of the lines I see have some level of wear. I suspect it's either erosion or cavitation from air in the fuel
Reply #12June 04, 2013, 08:18:15 am
wolf_walker
  • 1205
Re: Re: Re: Hard line wear?
« Reply #12 on: June 04, 2013, 08:18:15 am »
That's all I could think of. Ever bothered to clean em up?
Mentat Text Two
Reply #13June 04, 2013, 11:50:38 am
Re: Hard line wear?
« Reply #13 on: June 04, 2013, 11:50:38 am »
I don't see any advantage to trying to clean them up. It's probably all the way through the lines.
Reply #14June 13, 2013, 01:28:45 pm
92EcoDiesel Jetta
Re: Hard line wear?
« Reply #14 on: June 13, 2013, 01:28:45 pm »
Are the Prothe set plated or do they rust?
