Author Topic: Heat only coming from dash vents, no defrost?  (Read 6040 times)
May 14, 2013, 05:31:31 am
VTPSD
  • 107
« on: May 14, 2013, 05:31:31 am »
On my 91 ecodiesel jetta, I suddenly lost the ability to get heat from anything from the center vents (below stereo and the vents by the driver and passenger doors). I cant get it to blow from the defrost or the floor. When I play with the selector I can hear some noise and once in a while the defrost will come on, but then i can hear the door move a bit and its back to the center vents. My vac pump appears to work well, I checked the vac line that runs into the AC and it holds vacuum. Do I need to pull my heater box apart? Maybe something broke wit the flap? Not sure if this is a common issue with these things.
-1991 audi 90 quattro with AHU tdi, r520's holset he211
-1990 audi 90 quattro, holset turbo, 11 second quarter mile demon
Reply #1May 14, 2013, 05:42:30 am
VTPSD
  • 107
Re: Heat only coming from dash vents, no defrost?
« Reply #1 on: May 14, 2013, 05:42:30 am »
i should also add that the heat that does come out of the vents is very hot, and everything was working perfectly until just yesterday, so i dont think this is a foam on the flaps issue...
Reply #2May 14, 2013, 07:54:33 am
« Reply #2 on: May 14, 2013, 07:54:33 am »
There are a couple of plastic gears under the front of the airbox, by the vent/def-floor dashpot... maybe they are jammed with debris. You can see the gears & linkage easily with the console removed.
Reply #3May 14, 2013, 07:56:41 am
VTPSD
  • 107
« Reply #3 on: May 14, 2013, 07:56:41 am »
i will give those a look first, thanks. Does the vacuum selector above the temp control ever go bad? Not even sure how i would test that.
Reply #4May 14, 2013, 08:01:15 am
« Reply #4 on: May 14, 2013, 08:01:15 am »
I imagine it can go bad.
The "normal" position for the vent damper is in the defrost-floor position, so you might try running the system with the vacuum disconnected, to see if the air goes the up to the defrost outlets.
Reply #5May 14, 2013, 08:04:19 am
VTPSD
  • 107
« Reply #5 on: May 14, 2013, 08:04:19 am »
thats a good idea..strange that mine has seemingly defaulted to vents. I can clearly hear something moving when i switch the heat on and off, is there a second vac actuator that could still be moving, perhaps for fresh air vent?
I will check it out a bit more tonight and report back.
Reply #6May 14, 2013, 08:11:54 am
williamtaygan
  • 33
    • Arctic Vegwerks
« Reply #6 on: May 14, 2013, 08:11:54 am »
Do you have a Bentley? There are three (Four?) vacuum actuated flaps on the 91 Eco Check and make sure these are all moving at the proper time. If there is a vacuum leak, they will not move from the default positions. If those all work, you may have a chunk of foam stuck inside?  I had a problem with my 91 Eco not moving from the center to the defrost. But not with the heat/cold.  I just started parting out my 91 eco, so I might be able to help you out if you need something.
1981 1.6 NA Pickup
1982 1.6 NA Westfalia
1990 1.6 NA Jetta (not running)
1991 1.6 eco Jetta
1994 1.6 TD Jetta
Reply #7May 14, 2013, 08:34:37 am
« Reply #7 on: May 14, 2013, 08:34:37 am »
imo foam fell off... defrost is default.. max heat is too.. but heat is the "bpttpm gear" i think on bottom of box.. been too long since i screwed with one.. if it moves with no temp change.. foam gone
Reply #8May 14, 2013, 08:44:53 am
VTPSD
  • 107
« Reply #8 on: May 14, 2013, 08:44:53 am »
i can change my temp no problem, goes from cold to very hot just like it should, just cant get it to blow out of defrost or floor. I was messing with it on my drive to work this morning, and all of the sudden it selected defrost..then i moved it to floor, and to floor it went, then i hear something move inside, and its back to vents only. Strange. Hoping to avoid pulling the heater box out...we shall see.  ::)
I do have a bently, ill dig that out too.
Reply #9May 14, 2013, 06:04:14 pm
VTPSD
  • 107
« Reply #9 on: May 14, 2013, 06:04:14 pm »
found the issue, the gear/lever that actuates the door in question was broken. Anyone have one of these laying around they want to sell?
 :P
Reply #10May 14, 2013, 06:23:43 pm
williamtaygan
  • 33
    • Arctic Vegwerks
« Reply #10 on: May 14, 2013, 06:23:43 pm »
Lucky lucky! I've got one for you.  I'm parting out my 91 Jetta Ecodiesel this week.
Will in Alaska
 :P
1981 1.6 NA Pickup
1991 1.6 eco Jetta
1994 1.6 TD Jetta
