» TDI Engine -General Info
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
Removing the Catalyc Converter
1Z/AHU Intake Manifold Cleanse - few questions
Torque specs 1Z Rod and head ?
Oops
Ultra low mileage 2001 Jetta TDI 5speed
my 95 GTI TDI project
Dinged up piston replace?(ahu)
AHU timing belt tensioner new or old
ALH Build Up
TDI AHU Problmes
GT15 on 1.6 shifter clearance problem
MKIII Jetta TDI (AHU) - Anyone found a PDF Shop manual?
PD130 Turbo. To manifold, or not to manifold... that is the question.
6 speed box will it fit mk2 golf
Camshafts
mk3 99 TDI upgrading turbo, few questions
Is Alternator same on 2001 Jetta as 97 Passat?
Biodiesel and fuel lines...
Hard to start
info gear shift
1Z- ALH same cam?
2000 Jetta possible buy but vibrates consistent with RPMs
Can't prime the IP after engine rebuild
"CYT" TDI Transmission
opinions on a gas to dsl swap
ALH Intake cleaning
AAZ vs 1.6TD for MTDI
Rotella 5w-40 synthetic for ALH?
1999 mk3 tdi has a bunch of codes. Please help!
Bought car in pieces rebuilt now no start?
mTDI
EGR code 00560 ( 17-10 )
modified/aftermarket inlet manifold pics
Replacing dual mass flywheel?
Things I cannot post elsewhere....
Prothe Injector Nozzles
Testing TDI(out of car)
Mechanical to Computer TDI...
GT2052V on a fairly stock AFN...
Bypassing the AC
Whats the max an AHU pump can do?
hey guys! got a 2003 alh wagon
2009 TDI Miss firing
Puzzled ???
98 Jetta TDI eng. stuck
Bosio PP520 vs. OEM ?
newbie
AFN strange problem
03 TDI running super cool after EGR delete...normal?
anyone know about powerfull diesel engines?
