» TDI Engine -General Info
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
code trasmission
Discussion Topic - Infinite angle valve seats
autoenginuity scanner cable
Stock AirBox Question
more mTDI pump questions...
New TDI Owner!
How to make 2.0 TDI in 1.9 TDI-PD 8v ARL?
Where is the specs sticker?
How to remove injectors on PD engines.
MK4 150 bhp problem.
vnt vac control vs. boost control
Coolant glow plug effectiveness
Question on a service manual
Tdi into mk2?????????????????????????????????????
2004 Gls TDI Jetta.
need a little help
another mileage question on 2006
Problems timing a TDI
Just a couple Q's. TDI isn't my game
What turbo??
V10TDI engine on NISSAN SAFARI
pistons for compounds
SDI donor for mTDI??
revo tune
Working with my daily TDi and project mk2 Jetta
TDI driveshaft length with 6 speed box
Overboring a 1.9 TDi
Compressor Map for VNT15
upgrading a disco pump
Few choice ingredients....what engine/pump combo to build
Biggest WG turbo I can run?
i just dreamed a new set up
Aftermarket Turbo Controller for m_TDI's
shutdown shudder...
Is this normal wear on CR bearings? Looks odd...
Landrover Disco Pump Part number
Um....where do the lines go?
1.6 gtd engine and turbos?
2009 Jetta Sportwagen - Newbie here and to Diesel
Mtdi Pump 2.8 LT
depressing
PD/VE compression ratio dilemma
Nozzles for the 2.5 V6 TDI?
trubo leaking oil
mTDI won't run, possibly flywheel issue?
i want the biggest VNT you can get, is this it?
snakes mk2 golf build
Inlet manif. 1.6 or AAZ
merry christmas
Timing on a M-TDI and AHU
