» TDI Engine -General Info
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
your thoughts please
2.5 tdi engine to gaser gearbox will it go
1998 Jetta TDI - NEED ADVICE
1.9 TDI in a Tahoe?
AHU Cylinder Head Rebuild - Free or Cheap Mods?
Black Smoke Don't know why?
TDI in desert rally Buggy ?
need help urgently, anyone know about diesel main bearings?
TDI into Transporter
Manually controlling the EGR
TDI rolling misfire
Intake Manifold
1z pistons in ALH block?
VNT control question
Overheating TDI..what to do?
T4 1.9TD/1.9TDI Hybrid
Air in fuel??
MK4 Gas to TDI swap
Help - 1995 VW Passat 1.9 TDI (1z engine) no fuel on cranking
MTDI coolant heater glowplugs
Radial/axial play, how much is ok without leaks?
Source for rod and main cap bolts--04 Pump Duce motor
2001 Golf 1.9l TDI ALH No start
81 Rabbit with 1.9TD?
ALH/AHU injection pumps interchangeable?
Golf Syncro Mtdi (MKIII)
ALH identification please...
hmmmmmm
VAG V6 2.5TDi-M
2010 Volkswagen Golf TDI
2001 polo 90hp tdi, turbo from golf fits or not? ALH GT1749V
jetta code 1248
ARP head bolt torque
mTDI nozzles and breaking pressure
MTDI idle vibration
2002 1.9 tdi wont start
Fan cooled intercooler
Pistons for ALH
mtdi throttle cable bracket
Straight pipe exhaust..?
Uk ahu wiring diagram needed pls
1998 1.9 TDI Air in Line won't start
lightened flywheel??
Going TDI in MK2
AEL timing?
Seized engine??!!
it modifies mk1
VNT turbo on a JX manifold
Street Toys VNT actuator
compression ratio of ahu pistons
