TDI Engine -General Info
MTDI idle vibration
Topic: MTDI idle vibration (Read 4439 times)
May 08, 2010, 11:25:19 am
Andrewb
MTDI idle vibration
May 08, 2010, 11:25:19 am »
I've had my LR 200tdi pump running in the van for a while now, its seems to be running well and making about the right amount of power. The problem is that it vibrates quite a lot at idle, so I was wondering if anyone here had an idea of what might be causing it. The pump is completely standard, still need to do the govenor mod.
Thanks
Andrew
May 08, 2010, 03:09:35 pm
CdnVWJunkie
Re: MTDI idle vibration
May 08, 2010, 03:09:35 pm »
If you increase the RPMs a little with the accelerator pedal does the vibration go away or lessen?
May 09, 2010, 12:52:49 am
Andrewb
May 09, 2010, 12:52:49 am »
Yes, that stops it.
May 09, 2010, 09:54:15 pm
neimis
May 09, 2010, 09:54:15 pm »
Are your engine mounts good? A new passenger side mount transformed my car from vibrating and shaking to smooth and purring. I replaced all the others as well, just to be sure. (Until I got the old mount removed, I could not actually tell that it was bad)
'92 Passat TD
'01 Golf TDI
'15 Golf TDI
May 10, 2010, 09:51:19 am
snakemaster
May 10, 2010, 09:51:19 am »
i would have a look at the engine mounts ,have you seen ones from a A4 /pasat there real soft , i dont no if you got the room to fit them , i cant rember which ones you have fitted is it landrover ones , what dose your van tick over at .
Glenmorangie single highland malt
May 10, 2010, 10:58:04 am
Andrewb
May 10, 2010, 10:58:04 am »
Ye, I'm on Landrover mounts atm, which are pretty rock solid tbh. Looks like finding some softer ones is the place to start.
Still need to get a rev counter, so can't say exactly what my idle speed is.
Any ideas of where to get softer landrover style (round with studs both sides) mounts?
Thanks
Andrew
May 13, 2010, 03:29:38 pm
snakemaster
May 13, 2010, 03:29:38 pm »
i got a set for a capri/ cortina for my manta a when i put the diesel in her seem a good bit softer than LR , what you done with your gearbox mount ?
May 17, 2010, 01:25:27 pm
Andrewb
May 17, 2010, 01:25:27 pm »
Ye, just ordered those type of mounts actually.
I'm using the mount that came from the sierra with the type 9, which mounts to a craddle I made for the g/b
MTDI idle vibration
