Author Topic: MTDI idle vibration  (Read 4428 times)
May 08, 2010, 11:25:19 am
Andrewb
MTDI idle vibration
« on: May 08, 2010, 11:25:19 am »
I've had my LR 200tdi pump running in the van for a while now, its seems to be running well and making about the right amount of power. The problem is that it vibrates quite a lot at idle, so I was wondering if anyone here had an idea of what might be causing it. The pump is completely standard, still need to do the govenor mod.
Thanks
Andrew
Reply #1May 08, 2010, 03:09:35 pm
CdnVWJunkie
  • 309
Re: MTDI idle vibration
« Reply #1 on: May 08, 2010, 03:09:35 pm »
If you increase the RPMs a little with the accelerator pedal does the vibration go away or lessen?
Reply #2May 09, 2010, 12:52:49 am
Andrewb
« Reply #2 on: May 09, 2010, 12:52:49 am »
Yes, that stops it.
Reply #3May 09, 2010, 09:54:15 pm
neimis
  • 75
« Reply #3 on: May 09, 2010, 09:54:15 pm »
Are your engine mounts good? A new passenger side mount transformed my car from vibrating and shaking to smooth and purring. I replaced all the others as well, just to be sure. (Until I got the old mount removed, I could not actually tell that it was bad)
'92 Passat TD
'01 Golf TDI
'15 Golf TDI
Reply #4May 10, 2010, 09:51:19 am
snakemaster
  • 405
« Reply #4 on: May 10, 2010, 09:51:19 am »
i would have a look at the engine mounts ,have you seen ones from a A4 /pasat there real soft , i dont no if you got the room to fit them , i cant rember which ones you have fitted is it landrover ones , what dose your van tick over at .
Reply #5May 10, 2010, 10:58:04 am
Andrewb
« Reply #5 on: May 10, 2010, 10:58:04 am »
Ye, I'm on Landrover mounts atm, which are pretty rock solid tbh. Looks like finding some softer ones is the place to start.
Still need to get a rev counter, so can't say exactly what my idle speed is.
Any ideas of where to get softer landrover style (round with studs both sides) mounts?
Thanks
Andrew
Reply #6May 13, 2010, 03:29:38 pm
snakemaster
  • 405
« Reply #6 on: May 13, 2010, 03:29:38 pm »
i got a set for a capri/ cortina for my manta a when i put the diesel in her seem a good bit softer than LR  , what you done with your gearbox mount ?
Reply #7May 17, 2010, 01:25:27 pm
Andrewb
« Reply #7 on: May 17, 2010, 01:25:27 pm »
Ye, just ordered those type of mounts actually.
I'm using the mount that came from the sierra with the type 9, which mounts to a craddle I made for the g/b
