View full version: TDI Engine -General Info
  1. Using only part of the ECU functions
  2. 2000 Beetle TDI Randomly Dies
  3. Note about checking glow plugs
  4. 1Z TDI crank bolt etc
  5. Attn Libby v6 mtdi
  6. Late style AAZ pump bracket w/ rover pump
  7. Removing the Turbo on an ALH
  8. Ported & Polished AHU project
  9. Low Coolant Temps in My Mk4 TDI Jetta
  10. '98 Jetta misfire on cold start, lacking power when cold
  11. Calibrating ALH Injectors
  12. Tdiclubers hate mtdi!!
  13. K03/K04 hybrid on a eurovan w/ rocketchip stage 3, bigger nozzles etc
  14. R5 TDi...
  15. Land Rover Pump for M-TDIs - Pump Mounting & Accelerator Cable
  16. Feeler Rover TDI injection pump
  17. Anyone use an ALH 2-piece pulley on an AHU?
  18. TDI glowplug solution from TDi Club courtesy of Vince Waldon
  19. Oil Squirters for TDIs - different than TDs?
  20. Cam sprockets.
  21. Are ALH rod bolts TTY?
  22. Tune+nozzles+surging turbo=BOOM!
  23. New simple twist on mechanical VNT control
  24. Where can I find Replacement nozzles for an automatic alh?
  25. how much luck....
  26. So I almost bought a turbo.. 45 trim OM617 T3.. NOW HOLSET
  27. Wastegate stuck or was tightened to much by the rebuilder
  28. Picked up another tdi caddy today, this one is a PD though
  29. Anyone considered a 16v mTDI?
  30. What type of nozzles are these?
  31. Someone with a 1Z/AHU and Vag-Com want to help me out?
  32. MOVED: 1984 Jetta , TDI WE MUST! (1.9 AHU M-TDI)
  33. Replace Nozzles
  34. Broken TB Question
  35. ALH block. Mech 1.6 IDI - doable?
  36. 2 Stage Turbos
  37. k14 reclocking
  38. I need a bigger turbo....
  39. eco diesel cat on mtdi?
  40. passat 110 tdi to mtdi but with e vnt 15
  41. Clocking the Hub on an ALH IP
  42. o2A gears into 02J trans
  43. Rebuild large engine electrical connector (round) AHU
  44. 2000 Jetta Lift Pump?
  45. Auto vs 5 Speed IP Question
  46. Stuck injector
  47. 1z upgrades
  48. help identifying these engine harness connectors
  49. Borg warner K0422-582 mazda gasser turbo on a tdi?
  50. Non VNT turbo selection?
