Author Topic: Oil Squirters for TDIs - different than TDs?  (Read 4980 times)
November 06, 2013, 05:21:43 pm
« on: November 06, 2013, 05:21:43 pm »
Anyone know if the oil squirters for the TDIs are really that different from the TD ones?
Best price I'm finding for TDI squirters is about $30/ea with prices going up to $47/ea, whereas I've seen the 1.6TD ones for less than $10.
Reply #1November 06, 2013, 06:54:57 pm
Re: Oil Squirters for TDIs - different than TDs?
« Reply #1 on: November 06, 2013, 06:54:57 pm »
Any of the part numbers cross refernce
Reply #2November 06, 2013, 07:44:12 pm
« Reply #2 on: November 06, 2013, 07:44:12 pm »
There was a change with the TDI squirters, but I don't recall if it is mid-run on the AAZ or mid-run on the AHU/1Z.  They went to a single hole banjo style squirter instead of the 1.6TD style that has a hole for the oil valve and a hole for the bolt.
Reply #3November 06, 2013, 09:58:41 pm
« Reply #3 on: November 06, 2013, 09:58:41 pm »
Gotcha - that'd probably be it.  All the 1Z/AHU ones I've seen have been the banjo style, so I'm guessing it changed during the AAZ run.
Another day, another $120....
Reply #4November 06, 2013, 10:40:18 pm
« Reply #4 on: November 06, 2013, 10:40:18 pm »
All the AHU 1Z ones I have seen are identical to the 1.6 ones. I've taken apart 99 AHUs as well.
I have a bunch of used ones available if you need that style.
Reply #5November 07, 2013, 06:52:11 am
« Reply #5 on: November 07, 2013, 06:52:11 am »
According to ETKA they changed the squirters mid-run of BOTH the AAZ and the AHU.  The transition block number for the AAZ is 720935.  The transition code for the AHU is 100000.
Reply #6November 07, 2013, 09:28:56 am
« Reply #6 on: November 07, 2013, 09:28:56 am »
Thanks - I still have mine and they are all undamaged (or at least they were when the block went in to the machine shop!!) - I know on the 1.6 side everyone was generally saying to replace them at rebuild?
Gotcha - when I get my block back I guess I'll have to see what I actually have, didn't look that closely at the time.
