» TDI Engine -General Info
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
Is it possible to reverse mount a VP37, and how to?
vin no
ARP head studs from Canada?
BOV on a TDI
My TDI project - Phase 1
question about transmision installation
I SCORED!! (I Think...) Now How do I convert it????
1Z/AHU vs ALH?
2.0L Diesel question?
TDI Piston Ring Placement and Rod Bolt Reuse....?
A few TDI-M questions
dynoed m-tdi, incomplete
Camplate swap ?'s
12mm pump
mechanicaly increasing fuel - AHU pump
Anyone have SDI intake manifold PN's??
Interoperability of B3 Passat master/slave clutch with O2J
heres some initial gtech RR numbers on the tdi-m
TDI HD parts
Here's a TDI queston
Better turbo for TDI-M?
Timing port on TDI plunger heads
Quick question: TDI to M-TDI
Passenger TDI cam dyno results!
3" DP pictures :)
ALH Pump on 1Z/AHU?
2005 MK4 TDI...NEED INFO ON TUNNING
used TDI engines?
Mechanical TDI break in?
pics of dem total seal rings
what's a good source for oversize pistons for a TDi engine?
How to Build a TDI-M with Highest possible MPG in Mind.
TDI engine tech
TDI injectors
inline pump on a TDI
changing transmission oil
Delivery valve mods
Max boost pressure?
tdi life expectancy?
whats with this new 15ppm diesel fuel??
TDI vs TDI-m/TD-IDI with VNT
Audi A4 stock turbo?
TDI boost problem, please help...
TDI parts to use??
Head gasket choices
Advice for ACT Clutch
fiat ducato 2.5 td (1991) plunjer size?
150 HP
Would a 6 speed manual tranny fit a 1.9 diesel?
DieselPower tuning box for 99-03 tdi's ???
