View full version: TDI Engine -General Info
  1. TDI head porting link
  2. Substitute a VNT 15 by VNT17
  3. Check Engine Light
  4. EGR delete
  5. not your average clutch questions,
  6. Establishing a base of information (swapable parts)
  7. remote start on a diesel?
  8. what's the best oil for a 2000 TDI
  9. putting SVO in a TDI
  10. MKIV ignition switch in MKII column
  11. how much does a AT hurt MP's
  12. 9gand too much for a 00 TDI?
  13. tdi-M glow plug question
  14. turbo question
  15. tdi rebuild kit
  16. Shaving (and saving) the pistons ALH/AHU...thoughts,comments
  17. 11 mm or 12 mm in a 1Z pump?
  18. T03 In a TDI
  19. Custom TDI cams
  20. vnt 20 hybride
  21. SDI variable runner length intake manifold
  22. mechanical injected tdi running
  23. cleaned out my egr
  24. Vnt15 control solution wanted.
  25. 98 tdi crank bolt
  26. 98 Jetta TDI
  27. A3 AHU TDI into an A2 Golf/Jetta chassis
  28. tdi block
  29. Performance??
  30. High mileage Audi 2.5Tdi v6
  31. my TDI smokes for the first 5 min when starting
  32. TDI Knock??
  33. need help w/ahu tdisetup
  34. tdi engine swap
  35. Link to previous topic regarding VE pump number breakdown
  36. What is involved in setting up a tdi to run with a mech pump
  37. Reliability TDI in NewBettle?
  38. RWD trans for TDI?
  39. Intercooler Tubing for 2001 ALH with VNT-15
  40. Anyone interested in A4 Mann provent install...
  41. TDI pump rebuilding places?
  42. Something sinister in the works...
  43. Exhaust System on a engine swap?
  44. safe amount of boost
  45. 303K miles is all she's got!!!! Carnage UPDATED!!
  46. what belt setup on a tdi
  47. Newbie needs advise on Engine Swap.
  48. Custom Intake Manifold
  49. turbo diesel mileage
  50. how do i tell if a 97 jetta IS a tdi?
