View full version: TDI Engine -General Info
  1. Veg service?
  2. #3 injector line keeps cracking
  3. Motor Oil
  4. Building an M-TDI pump
  5. New Member
  6. MTDI Alternative Donor Pumps
  7. TDI Help!!!
  8. My soon to be new car
  9. 1.6 turbo & manifold on a TDI?
  10. 96 passat tdi dead cluster
  11. Alternator swap
  12. power cutting out.
  13. what years was the ALH produced?
  14. egt wire splice
  15. TDI Piston
  16. Need some advice or opinions
  17. Veg-216 nozzles
  18. My new 2009 Jetta TDI
  19. Kerma
  20. 2002 TDI Chirp
  21. Who builds good diesel engines ?
  22. MK4 TDI 4motion
  23. 2000 tdi starter pinon teeth numbers auto verses man. trans
  24. 03TDi wagon CEL no boost
  25. 2l engine swap?
  26. How about PD170's
  27. My first TDI.. just one issue to figure out..
  28. Project: Audi A4Q6MT TDI...
  29. VP37 signal characters
  30. chip suggestions
  31. m-TDI Vanagon
  32. pulse time land rover pump on tdi
  33. MY GLX conversion
  34. B4 to A3 cabrio quick tdi swap What can i expect?
  35. 2000 ALH anti-shutter valve open "all" the time
  36. 2006 tdi smoke on startup
  37. ALH ECU difference
  38. Anyone know this car?
  39. Very rough starts on my ALH
  40. 01 ALH power steering pully... delf destruction...
  41. VNT-17 on ALH
  42. Hard injector lines
  43. Difference between 1Z and AFN Engine
  44. Veg injection service?
  45. Need clarification on using a 4BT Injection Pump for a MTDI
  46. PD timing belt
  47. 98 jetta tdi into a 84 jetta td
  48. Mtdi mk1 rabbit Information wanted!!
  49. TDI stumbles and miss fires
  50. Headgasket failures
