Author Topic: 2000 tdi starter pinon teeth numbers auto verses man. trans  (Read 3930 times)
October 10, 2011, 05:45:53 pm
madrogers
  • 165
« on: October 10, 2011, 05:45:53 pm »
 i was replaceing the starter on the wifes jetta , 2000, auto.  the starter i got from the wpg jobber was a bosch reman # sr0407x , pulled  the starter from the car and it has a 1 inch apx pinion with 9 teeth on it , the reman has a 1.125 " pinon with 11 teeth on it ,
from what i can find on the interweb the part number is right but no real talk about the number of teeth.
I belive that  it is the right # but with the wrong pinion on it  can any body confirm the number of teeth on a man. trans starter/ or any other info woulds help before i call them tomorrow about it.
Thanks
83 CADDY 1.6 TD WINTER
83 CADDY 1.9 AAZ SUMMER
Reply #1October 10, 2011, 08:40:24 pm
nathan_b
  • 361
Re: 2000 tdi starter pinon teeth numbers auto verses man. trans
« Reply #1 on: October 10, 2011, 08:40:24 pm »
at = 9 teeth,
mt = 10 teeth
both 1.8kw
both gear reduction
but. I would wager that they would work OK swapped, but not ideal..
Reply #2October 10, 2011, 08:43:40 pm
madrogers
  • 165
« Reply #2 on: October 10, 2011, 08:43:40 pm »
that weird the pinon has 11 teeth  counted them 3 times.
Reply #3October 11, 2011, 04:15:28 am
BigVWman
  • 332
« Reply #3 on: October 11, 2011, 04:15:28 am »
They are also different nose depth and no dice changing heads they are different diameter also! I have a spare auto starter if you end up needing one lmk
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
