View full version: TDI Engine -General Info
  1. 97 TDI 1Z engine for 130whp, help please...
  2. Automatic Golf TDI on Nitro
  3. spia olio .risolto problemi adesso tutto OK
  4. starting an engine
  5. risolto problema spia olio
  6. Best matched 02a for the MK1 and the b3 project...
  7. What Would You Buy For your Car/Engineif You were in Europe
  8. i'm curious
  9. Audi 5 pot (AAT) tuning ?
  10. Audi 5-Cyl TDI (AAT) From Europe with a Giles Mech TDI Pump!
  11. we need an electrical wiz for a VNT
  12. Light oil pressure
  13. spia dell'olio motore fuso?
  14. spia olio motore
  15. p.s. spia olio
  16. TDI as generator
  17. Pre-1996 TDI injectors.....single stage?
  18. Corrado TDI conversion at last!
  19. info on t4 van turbo
  20. gov shim M tdi
  21. Chipping TDIs in the UK
  22. SOME IMPORTANT BOSCH VE PUMP INFO...)
  23. timing with a timing light
  24. ALH tranny mods?
  25. dry or wet ring setup
  26. AHU ECU's Are they Interchangeble?
  27. 1.6d/1.6TD serpentine accessories?
  28. T15/22 hybrid for m-TDI
  29. 2.8 tdi
  30. M-TDI with top end issues
  31. help!
  32. mk2 tdi
  33. Bosch 2.8 VE Pump
  34. 1.5 Tdi, possible?
  35. need some more power from my 1Z engine
  36. Which fixed geom. turbo for an AHU mTDI ?
  37. injector bolt torque
  38. 1990 VW Diesel Golf Steering problem
  39. SVO in tdi
  40. Which maniflds fit?
  41. Source for BEW/ BRM rebuild parts
  42. Crank bolt torque
  43. vnt25 on a Tdi-m
  44. Valve springs watts best
  45. AHU bore size
  46. Disconect EGR on a TDI???
  47. Alternate MAF sensors
  48. should i go through the trouble?
  49. Bottom end strength
  50. older tdi engines???
