TDI Engine -General Info
timing with a timing light
Topic: timing with a timing light (Read 3571 times)
March 14, 2008, 11:02:23 am
March 14, 2008, 11:02:23 am »
Do any of you time your engines with a timing light? if so, what do you set it at?
March 14, 2008, 01:37:14 pm
burnt_servo
March 14, 2008, 01:37:14 pm »
what are you using to get a reading for your timing light ?
i've got a snap on adapter that clamps onto the no 1 injector line .
on the mitsubishi diesel i had , 5 degree's after tdc is where it liked to live . that is the starting point ill be using myself , unless the stock timing is radically different .
haven't messed with the timing on my vw yet . can you even easily see the timing marks on the flywheel ?
1990 jetta , tweaked pump , tweaked turbo , ported head 2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
March 14, 2008, 02:17:26 pm
March 14, 2008, 02:17:26 pm »
I ordered a pickup for a tiny tach which I will adapt to my gas timing light. I will time it off the TDC mark I made on the crank pulley.
March 14, 2008, 09:50:13 pm
Quantum TD
March 14, 2008, 09:50:13 pm »
I think Andrew (libbybapa) has a professional uint for IDI timing. He might lend some insights on how to for your TDI-(M?).
March 18, 2008, 09:53:45 pm
March 18, 2008, 09:53:45 pm »
Got my pickup this evening.
