Author Topic: timing with a timing light  (Read 3564 times)
March 14, 2008, 11:02:23 am
« on: March 14, 2008, 11:02:23 am »
Do any of you time your engines with a timing light? if so, what do you set it at?
Reply #1March 14, 2008, 01:37:14 pm
burnt_servo
  • 278
« Reply #1 on: March 14, 2008, 01:37:14 pm »
what are you using to get a reading for your timing light ?
i've got a snap on adapter that clamps onto the no 1 injector line .
on the mitsubishi diesel i had , 5 degree's after tdc is where it liked to live . that is the starting point ill be using myself , unless the stock timing  is radically different .
haven't messed with the timing on my vw yet .  can you even easily see the timing marks on the flywheel ?
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #2March 14, 2008, 02:17:26 pm
« Reply #2 on: March 14, 2008, 02:17:26 pm »
I ordered a pickup for a tiny tach which I will adapt to my gas timing light. I will time it off the TDC mark I made on the crank pulley.
Reply #3March 14, 2008, 09:50:13 pm
Quantum TD
  • 1195
« Reply #3 on: March 14, 2008, 09:50:13 pm »
I think Andrew (libbybapa) has a professional uint for IDI timing. He might lend some insights on how to for your TDI-(M?).
Reply #4March 18, 2008, 09:53:45 pm
« Reply #4 on: March 18, 2008, 09:53:45 pm »
Got my pickup this evening. :D
