Author Topic: AHU bore size  (Read 3440 times)
February 16, 2008, 06:22:03 pm
boxer246
  • 109
AHU bore size
« on: February 16, 2008, 06:22:03 pm »
I dont have a Bentley (yet) and cant find a spec sheet anywhere.....can someone please tell me what the new bore size and out-of-spec bore limit is for a AHU?   Looking at a motor that is apart and want to see if it is going to need a rebore.  The guy said the motor has 225,000 miles, but I tell you the bores looked perfect....hone marks still clearly visible, and no ridge at top of bore was discernable...so who knows.   I measured the bore with my crappy T-guage and came up with 3.130".
Ash
'81 VW Caddy 1.6 now a TD
'88 Vanagon (building a AHU M-TDI)
Reply #1February 16, 2008, 07:05:32 pm
AHU bore size
« Reply #1 on: February 16, 2008, 07:05:32 pm »
Bore is 79.5 mm, or 3.13". Looks like you should be good.
Reply #2February 17, 2008, 01:09:21 am
MikkiJayne
  • 235
AHU bore size
« Reply #2 on: February 17, 2008, 01:09:21 am »
AHUs seem to be pretty much invincible in that respect. Mine had 180K when I tore it apart. The bearings were worn to nothing, but the bores are still perfect. A quick hone and it's good to go  8)
Reply #3February 17, 2008, 02:54:17 pm
boxer246
  • 109
bore
« Reply #3 on: February 17, 2008, 02:54:17 pm »
Thanks for the info fellas.
Ash
