Author Topic: Note about checking glow plugs  (Read 4256 times)
February 02, 2014, 06:57:22 am
  • 1739
« on: February 02, 2014, 06:57:22 am »
In the past, a quick test for GP's was to take a test light, clamp one side to battery positive and touch the other side to the tip; if the test light lit you had continunity= good PG. If one was suspect, pull it out and bench test to directly on a battery. A couple of weeks ago with the deep cold  we had I cycled my key a couple of times to help the engine start. Soon after my MIL came on and so I checked each GP as usual and found all of them tested okay with the test light; so i figured it was the buss bar. I replaced the buss bar, but a couple of days later, MIL came on again. So yesterday I went and checked them with an ohm meter. 3 were less than 1 ohm, one was 166 ohms. Took it out and bench tested and it lit up. I replaced it and now no more MIL. I even used a test light with a neon bulb which supposed to not light up brightly with a higher resistance in the circuit. Lesson learned
Reply #1February 02, 2014, 10:09:31 am
Re: Note about checking glow plugs
« Reply #1 on: February 02, 2014, 10:09:31 am »
wow, I had the same issue recently.
I also had the same deal you spoke about earlier with the vanishing coolant when it gets really cold. I don't know what is going on there and I am open to your ideas. Brightest thing I am thinking is the plastic connectors at the heater core shrink when it is that cold allowing a little to escape until the engine warms up. I never lose too much, but don't see it anywhere either???
Reply #2February 03, 2014, 07:53:14 pm
  • 1739
« Reply #2 on: February 03, 2014, 07:53:14 pm »
Coolant loss was my head gasket. I changed it last week and it was obvious where it failed- at the back edge of cylinder #1. Now fires up cold smoother than before also.
Reply #3February 03, 2014, 07:56:46 pm
  • 1739
« Reply #3 on: February 03, 2014, 07:56:46 pm »
Of course I figured that was the problem because the colder it got, the more pressure was building up in the tank, and staying pressurized for even a couple of days. So much was blowing out when coming to a stop off a highway ramp,I was worried that it would ruin my L/S strut bearing.
Reply #4February 03, 2014, 08:20:19 pm
« Reply #4 on: February 03, 2014, 08:20:19 pm »
I never see any coolant and it takes a long while to lose any. I hope no HG in the near future.
Reply #5February 04, 2014, 08:35:07 am
  • 1739
« Reply #5 on: February 04, 2014, 08:35:07 am »
Hope for your sake it's not an even worse scenario than me. What is the possibility that you are consuming it? Or if it was the EGR cooler I would have thought you would have evidence of that in the bottle. I have had success using a Snap on combustion gas tester that reads from the bottle;worse case was finding a cracked block on a pal's AAZ Vanagon, but he had an overheating issue.
Reply #6February 04, 2014, 04:50:17 pm
« Reply #6 on: February 04, 2014, 04:50:17 pm »
It only does it when it is around 0f
