Author Topic: ALH block. Mech 1.6 IDI - doable?  (Read 7980 times)
August 30, 2013, 11:30:46 am
vdubspeed
  • 191
« on: August 30, 2013, 11:30:46 am »
I'm starting to acquire a good amount of spares. I bought an 00 Jetta TDI with the blown t-belt that has sat for 5 years and the owner lost the head. I have plenty of 1.6 IDI heads around.
I was thinking of building a super hybrid just for laughs and giggles.
From my understanding I will have pretty insane compression but other than that...it's cool?
I've read about AAZ and other 1.9 motors with 1.6 heads but not an ALH block. I have the turbo too so I could toss it a little boost to cool it down:)
Thanks,
Jason
Reply #1August 30, 2013, 12:10:19 pm
bbob203
  • 1789
Re: ALH block. Mech 1.6 IDI - doable?
« Reply #1 on: August 30, 2013, 12:10:19 pm »
I think the coolant passages and such are different on the alh and things wont line up. What pistons would you use? Also have to figure out what to do for injection pump.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2August 30, 2013, 12:36:54 pm
« Reply #2 on: August 30, 2013, 12:36:54 pm »
mechanical 1.6 has one less oil drain, if you plug the extra drain in the block and use a 1.6 mechanical head gasket it would all bolt together.  compression would actually be extremely low.
Reply #3August 30, 2013, 12:48:30 pm
« Reply #3 on: August 30, 2013, 12:48:30 pm »
The 1.6 head will bolt up to an AHU, but not an ALH.
1.6 mechanical head gasket:
ALH head gasket:
They are very different, not even close.  If an AHU block were bolted to a 1.6 head, then the compression would be very low, probably close to a gasser.
Reply #4August 30, 2013, 02:41:08 pm
« Reply #4 on: August 30, 2013, 02:41:08 pm »
If you used TDI pistons you'd have the combustion chamber still in the piston as well as the precup in the head..
I agree you would probably end up as a higher compression gas engine.. That you'd need to run on lubed up 100 octane. lol . The TDI is already down to 19.5:1, add that massive pre-chamber in there as well.. I dunno
Reply #5August 30, 2013, 02:47:09 pm
« Reply #5 on: August 30, 2013, 02:47:09 pm »
and the compression woul dbe completly screwed with tdi pistons in idi head..
Reply #6August 30, 2013, 06:17:11 pm
« Reply #6 on: August 30, 2013, 06:17:11 pm »
Just have to plug the extra drains, no big deal.
Reply #7August 30, 2013, 06:22:35 pm
« Reply #7 on: August 30, 2013, 06:22:35 pm »
You can't possibly be serious?
It's way easier than you make it seem..
Reply #8August 30, 2013, 06:30:50 pm
« Reply #8 on: August 30, 2013, 06:30:50 pm »
What??? Its aome crazy engine that makes no sense to assemble but i still wouldnt mind seeing it happen just to see what happens
Reply #9August 30, 2013, 08:14:22 pm
vdubspeed
  • 191
« Reply #9 on: August 30, 2013, 08:14:22 pm »
Well I plugged a hydro block and a mech head when I built a hybrid 1.6 IDI so I'm not worried about blocking ports.
I think as time allows I will put the two side by side and see what the real no B.S. stopping points are.
As for compression...that's the major pitfall as I cant just changed that.
Reply #10August 31, 2013, 12:17:59 am
bbob203
  • 1789
« Reply #10 on: August 31, 2013, 12:17:59 am »
dude it wont work the front oil drain on an alh is square.
03 Jetta wagon TDi
Reply #11August 31, 2013, 04:40:32 am
vdubspeed
  • 191
« Reply #11 on: August 31, 2013, 04:40:32 am »
Notice with your first comment:
Your tone was not certain. Key word is "think"
Then a picture of two headgaskets are posted and then your tone becomes firm:
I'm sorry, but I do not share in your blatant dismissal of the idea. I'm sure when Rudolph diesel said he was going to build a compression fired engine he was told it wouldn't work either.
So yeah, blocking the front oil plug on the head will be easy. As for the square part...that will take more ingenuity but by no means a deal breaker.
Now compression...that's what worries me. As for what injection pump, definitely the original IDI pump.
Reply #12August 31, 2013, 05:07:39 am
bbob203
  • 1789
« Reply #12 on: August 31, 2013, 05:07:39 am »
look at the headgaskets not the same shape. I'm all for making new things and creativity. I just think yoy ought to shift in anither direction with your creative energy.  8) I wasn't meaning to dissmiss your creative thinking.
03 Jetta wagon TDi
Reply #13August 31, 2013, 05:13:02 am
bbob203
  • 1789
« Reply #13 on: August 31, 2013, 05:13:02 am »
basically what in saying is try it with an ahu will make a little more sense.
03 Jetta wagon TDi
Reply #14August 31, 2013, 06:33:36 am
« Reply #14 on: August 31, 2013, 06:33:36 am »
I agree the earlier 1.5, 1.6 and 1.9 D's share the block with the AHU.. So it'd be only compression holding you up at that point.
