Author Topic: need help urgently, anyone know about diesel main bearings?  (Read 3067 times)
July 28, 2010, 02:10:42 pm
oldskool rich
  • 446
ok, 1Z main bearings are £19 a set
PD mains are £84 a set
they are the same size, infact ive used a set in my 2.0 block, they feel perfect, can anyone see a reason why i should pay the extra to get the PD ones? 1Zs never suffer with mains, im about to thow my engine in and dont wana bother if sumone has a bad word to say about doing this
talk to me
f6squared I.D.S.T
Reply #1July 28, 2010, 11:44:17 pm
oldskool rich
  • 446
Re: need help urgently, anyone know about diesel main bearings?
« Reply #1 on: July 28, 2010, 11:44:17 pm »
anyone?
f6squared I.D.S.T
Reply #2July 29, 2010, 05:02:55 am
« Reply #2 on: July 29, 2010, 05:02:55 am »
If they mic the same thickness and have the same dimensions there is no reason you couldn't use them. They are a babit bearing that is just lead with backers. Maybe a little more than that, but as long as they are the correct size I don't see an issue. I can't tell you to run it if it is 2 different part #s though, just to be safe. If you have already done it in a similar engine though you should be fine.
Reply #3July 29, 2010, 09:21:58 pm
TDIMeister
  • 284
« Reply #3 on: July 29, 2010, 09:21:58 pm »
No OEM uses lead for bearing material anymore. NO ONE.  Most are some combination of aluminium/copper/tin/zinc/antimony.
Rich, you ALWAYS get what you pay for.  4-layer sputter bearings, high-tech stuff, mucho ££££££.
