Author Topic: VNT control question  (Read 4188 times)
July 02, 2010, 10:28:40 am
lucasone
  • 25
« on: July 02, 2010, 10:28:40 am »
On a VNT turbo when vacuum is applied to the actuator pulling down on the rod, does this increase turbine speed(boost) or decrease?
Also when this happens are the vane in a closed position or open?
If anyone has any info on this topic, please let me know.
Thanks
Reply #1July 02, 2010, 11:18:55 am
rallydiesel
  • 1880
Re: VNT control question
« Reply #1 on: July 02, 2010, 11:18:55 am »
When vacuum is increased to the actuator, the vanes close and turbine speed increases . At no vacuum, the vanes are open and turbine speed decreases. Open/close is sort of inaccurate. It's the angle of the vanes that changes, they never actually close off exhaust flow completely, just change the velocity of the exhaust gas going through them.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2July 02, 2010, 01:30:37 pm
lucasone
  • 25
« Reply #2 on: July 02, 2010, 01:30:37 pm »
Thanks
Reply #3July 07, 2010, 11:15:39 am
lucasone
  • 25
« Reply #3 on: July 07, 2010, 11:15:39 am »
Looking at the VNT controll couldn't you replace the vacuum actuator with a boost actuator and controll it with boost?
Reply #4July 07, 2010, 06:16:48 pm
rallydiesel
  • 1880
« Reply #4 on: July 07, 2010, 06:16:48 pm »
I think vacuum is more easily controlled with an electronic solenoid. If you are making a mechanical vnt controller, then boost is what you will want instead.
Reply #5July 12, 2010, 07:31:31 am
OM617
« Reply #5 on: July 12, 2010, 07:31:31 am »
Yes but fuel economy and part throttle performance will be extremely poor due to the actuator causing very high exhaust backpressure.
Reply #6July 12, 2010, 10:44:58 am
« Reply #6 on: July 12, 2010, 10:44:58 am »
see, i knew you had good information once in a while!
Reply #7July 18, 2010, 09:08:28 am
OM617
« Reply #7 on: July 18, 2010, 09:08:28 am »
see, i knew you had good information all the time!
Yep, agreed.
