Author Topic: code trasmission  (Read 3521 times)
February 21, 2009, 11:03:48 am
sabatino
code trasmission
« on: February 21, 2009, 11:03:48 am »
hi to everybody, 'I have a transmission of the vw golf3 td 1992 75 cvs the code written on the bell of the change it is CHD 27102
                                             and under 1 14 would like to know if possible
what the relationships of the various marches and that are of the relationship to the final bridge
thanks to everybody.
Reply #1February 21, 2009, 01:28:01 pm
giulianot
  • 146
code trasmission
« Reply #1 on: February 21, 2009, 01:28:01 pm »
http://www.zelek.com/diagram_charts/diagramlist.htm
CHD,DFP,ATH     3.45     1.94     1.28     0.91     0.75     3.67      From '93 1.9L TD 75hp
1990 cabriolet 1.9 aaz, kkk 24/26,  Giles pump, big  2.5" intercooler,  3 " P.P. downpipe
Reply #2March 01, 2009, 08:54:53 am
sabatino
code trasmission
« Reply #2 on: March 01, 2009, 08:54:53 am »
:D thanks Giulianot,il site is complete, I have to replace the change because very short.
do you have suggestions for change conic couple or do I compare final?
my change is chd final relationship 3.67 too much tall of turns
other suggestions? a regard
Reply #3March 01, 2009, 09:11:30 am
code trasmission
« Reply #3 on: March 01, 2009, 09:11:30 am »
Quote from: "sabatino"
look for a CTN.  it is a stronger transmission, and the gearing is quite tall.  in fact, it seems to have the tallest ring & pinion gear of all the 02A/02J's
R&P          1st            2nd           3rd           4th           5th
3.157   3.778   2.118   1.360   1.029   0.755
approximately 56.8mph (91.4km/h) @ 2000 rpm with 14" tires.  just by upgrading your tires to 16" you could go 100km/h @ 2000 rpm.
Reply #4March 06, 2009, 04:58:58 am
sabatino
code trasmission
« Reply #4 on: March 06, 2009, 04:58:58 am »
:D thanks for the risposte,mas wanting to change that is only the final relationship the conic couple 3.67 with one more' long thing would change to the other marcie?os it suits me to change only the relationship of the scene 5° marcia?datemis you recommend my change it is too much short it reaches 162 km\hs in 5° to 3900 rpms and me from' 90 cvs to 71 km\hs
help help    help :(  :(  :(  :(  :(
