TDI Engine -General Info
SDI donor for mTDI??
Topic: SDI donor for mTDI?? (Read 2835 times)
January 20, 2009, 03:49:30 am
regcheeseman
January 20, 2009, 03:49:30 am »
Can I use a SDI engine as a donor for a mTDI build.
I'm thinking disco pump and a VNT......
Does the SDI bottom end and head have significant difference to the TDI's?
January 20, 2009, 04:33:47 am
snakemaster
January 20, 2009, 04:33:47 am »
the CR is rufflay the same , it may not have oil squrters, but will work ok , will need a oil return from turbo to sump as a tdi one goes to the block (easer to to do the sump ) oil feed from filter housing .
Glenmorangie single highland malt
