TDI Engine -General Info
Can't prime the IP after engine rebuild
Topic: Can't prime the IP after engine rebuild (Read 3525 times)
November 03, 2010, 06:46:59 am
MikkiJayne
November 03, 2010, 06:46:59 am »
Hi all,
I've put a rebuilt AFN in my A6 and I can't get the IP to prime
I've tried pulling fuel up to the filter, filling the pump at the inlet and even running it from a fuel can thats higher than the pump and nothing. All four injector unions are loosened and there is no fuel at any of them.
The only thing left that I can think of is that the pump has gone bad sitting in a box for 2 years. Is that likely or even possible?
Any suggestions welcome, because this thing is really beginning to annoy me now and I'm stumped
November 03, 2010, 06:48:03 am
Re: Can't prime the IP after engine rebuild
November 03, 2010, 06:48:03 am »
Have you tried applying suction at the "out" side of the pump?
November 03, 2010, 07:42:22 am
MikkiJayne
November 03, 2010, 07:42:22 am »
I will have done in about 10 minutes......
November 03, 2010, 08:02:21 am
MikkiJayne
November 03, 2010, 08:02:21 am »
Nothing
I can't suck anything through with a handheld rubber siphon pump. Does it need something stronger than that?
November 05, 2010, 12:17:54 pm
starrd
November 05, 2010, 12:17:54 pm »
What I do is use my Brake bleader vacuum pump to pull fuel into the filter, then connect to the return line from the pump to pull it into the injection pump. If you can't get it into the filter then you might have a blockage between tank and filter which I am sure you already know. I can't remember the vacuum I was pulling but I had no issues.
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
November 05, 2010, 12:19:45 pm
November 05, 2010, 12:19:45 pm »
Yeah, a rubber suction bulb might not be strong enough. I use my 6 litre oil evacuator, and even it pulls pretty hard.
November 07, 2010, 02:46:02 pm
MikkiJayne
November 07, 2010, 02:46:02 pm »
Sorted now
I used a gasser lift pump feeding the input to the pump. It didn't do anything static, but as soon as I turned it on the starter it primed and started
Thanks for the tips guys
