Author Topic: Camshafts  (Read 6464 times)
July 26, 2010, 03:01:35 pm
lucasone
  • 25
Camshafts
« on: July 26, 2010, 03:01:35 pm »
Does anyone know if the camshaft in a ALH(TDI 1.9) is the same as a AHU(TDI 1.9) cam?
I have a camshaft with a custom grind that works great in an ALH and I would like to put it in my AHU.
Reply #1July 27, 2010, 12:10:43 am
mrchill
  • 1
    • http://www.kraftwerke1.com
Re: Camshafts
« Reply #1 on: July 27, 2010, 12:10:43 am »
Typically you can use an ALH cam in an AHU\1Z application....you just cannot go the other way around....
How do you know you are alive if you are not miserable?
Reply #2November 08, 2010, 06:25:22 am
myke_w
  • 1099
Re: Camshafts
« Reply #2 on: November 08, 2010, 06:25:22 am »
mrchill, can you tell us more about the alh cam in the 1z /ahu? what differences are there?
Reply #3November 08, 2010, 01:09:17 pm
Re: Camshafts
« Reply #3 on: November 08, 2010, 01:09:17 pm »
I bet Dr. Diesel knows everything about the different TDI cams, and has specs for all of them.. just a guess tho..
Reply #4November 08, 2010, 08:28:23 pm
dieselherb1
  • 354
Re: Camshafts
« Reply #4 on: November 08, 2010, 08:28:23 pm »
I'd like to know also Mr. Wizard
Reply #5November 09, 2010, 03:11:53 am
Re: Camshafts
« Reply #5 on: November 09, 2010, 03:11:53 am »
You can not use a AHU/1Z cam (or earlier) in a 1.6 because the timing slot on the ALH is used to drive the vacuum pump.
This graph Dr Diesel and I worked on shows the lift and duration of the ALH but nothing on the AHU or 1Z.
http://img.photobucket.com/albums/v603/burnyourmoney/Camshafts2.jpg
Reply #6November 18, 2010, 01:14:19 am
smiffie88
  • 29
Re: Camshafts
« Reply #6 on: November 18, 2010, 01:14:19 am »
i put aaz cam into an alh head i just made the slot for the vacuum pump bigger
Reply #7November 22, 2010, 08:49:42 am
foxracer1
  • 991
Re: Camshafts
« Reply #7 on: November 22, 2010, 08:49:42 am »
I put an AAZ cam in my AHU/1Z.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #8November 27, 2010, 07:50:49 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
Re: Camshafts
« Reply #8 on: November 27, 2010, 07:50:49 am »
the alh can be swapped into the ahu from what I've read. Take a look here and other cam forsale threads on tdiclub and you will see similar info as found in this thread: http://forums.tdiclub.com/showthread.php?t=295122
I've also read on vwdiesel.net's older cam debate thread about how the AZZ cam is an upgrade for the AHU
