Author Topic: AAZ vs 1.6TD for MTDI  (Read 6444 times)
October 26, 2010, 05:49:16 am
dieselherb1
  • 354
« on: October 26, 2010, 05:49:16 am »
What is the difference between the AAZ and the 1.6TD pump? I want to use one with TDI camplate on a MTDI.
Reply #1October 26, 2010, 07:22:27 am
blackdogvan
  • 574
Re: AAZ vs 1.6TD for MTDI
« Reply #1 on: October 26, 2010, 07:22:27 am »
Probably better to start with a TDI pump & transfer your mechanical bits over to it rather than the other way. IDI pumps have a smaller shaft 17mm vs. 20mm IIRC) that has been found to fail by others.
1991 Vanagon 1.9 mTDI
Reply #2October 26, 2010, 08:42:37 am
« Reply #2 on: October 26, 2010, 08:42:37 am »
and there are others on here running a 17mm pump shaft with 14mm(12mm?) pump heads with no problems.
Reply #3October 26, 2010, 09:07:19 am
410
  • 581
« Reply #3 on: October 26, 2010, 09:07:19 am »
Has anyone ever broken a 17mm shaft in an mtdi pump?  I'm running a 11mm head on my aaz pump for over a year now with no troubles.  I personally would use the aaz pump over a 1.6td pump mainly because it has more dynamic advance.  Although it is possible to increase dynamic advance on the 1.6 pump as well.
Reply #4October 26, 2010, 09:47:05 am
« Reply #4 on: October 26, 2010, 09:47:05 am »
i, personally have never even heard of a broken shaft.. i suppose its VERY possible, just never heard of it happening. i suppose its basically the same as all the killer pre cups that people keep talking about.. another one of those things that ive never personally seen..
Reply #5October 26, 2010, 11:58:24 am
410
  • 581
« Reply #5 on: October 26, 2010, 11:58:24 am »
It would be a mess if it happened that's for sure.  If the pump shaft broke,  the pump would turn into scrap metal and if it was bad enough it could also break the timing belt and damage the motor.  :o
Reply #6October 26, 2010, 05:03:16 pm
« Reply #6 on: October 26, 2010, 05:03:16 pm »
if the pump rotor siezed/snapped, it may break the drive pin and the rest be alright
if the pump drive shaft snapped, then i dont foresee much hope for the valves and pistons..
my bet is that the end of the shaft would simply twist/break off and the pulley/belt would just fall..
Reply #7October 26, 2010, 06:34:43 pm
dieselherb1
  • 354
« Reply #7 on: October 26, 2010, 06:34:43 pm »
I didn't know you could convert a TDI pump to mechanical? Who has done this?
Reply #8October 26, 2010, 06:54:02 pm
rallydiesel
  • 1880
« Reply #8 on: October 26, 2010, 06:54:02 pm »
Are you kidding? What did you think an mtdi is? Not trying to be rude, but it's in your thread title.  ???
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #9October 26, 2010, 07:24:54 pm
« Reply #9 on: October 26, 2010, 07:24:54 pm »
I thought to make a TDI an M-TDI you had to convert an AAZ pump to work.. Didn't know you could also use an electronic TDI pump as your starting pump. Interesting.
Reply #10October 26, 2010, 07:34:31 pm
410
  • 581
« Reply #10 on: October 26, 2010, 07:34:31 pm »
A real tdi pump does not have the pivot bolt holes for the control lever.  Plus I have also heard of no governor.  So you use the guts of the tdi pump in a td pump body.
Reply #11October 26, 2010, 07:51:35 pm
rallydiesel
  • 1880
« Reply #11 on: October 26, 2010, 07:51:35 pm »
Oh now I see what he meant.
Reply #12October 26, 2010, 09:24:07 pm
« Reply #12 on: October 26, 2010, 09:24:07 pm »
rover pump from the uk... 200-300$ and almost bolt on..
Reply #13October 27, 2010, 05:08:19 pm
dieselherb1
  • 354
« Reply #13 on: October 27, 2010, 05:08:19 pm »
Rover pump from UK $2-300 and $100+ shipping?
Reply #14October 28, 2010, 08:48:31 pm
« Reply #14 on: October 28, 2010, 08:48:31 pm »
mine was hand delevered.. :D was also 200$ us too.. but my friend was in the uk and picked it up to guini pig it.. well now i the guini pig.. and will mostlikely be march before i got it and the car going.. lots of stuff popped up.. else id probally have it loser to running then i do..
i have a thread in this section on "educate me on rover pumps" with good info from people who have used them.. ive even talked to 2 people thru im/pm who have used the pumps with success and one says lots of really nice hard to beleive numbers.. why its a guini pig thing for now..
goto the mod list, contact myke_w he can get ya more info as he has uk friends (buy via ebay uk and his friend will ship to him type of thing).. he has also shipped pumps to giles in the past and knows the custom/importing associated.. why having a friend ship to you is best as if you mess up the shipper/customs will be mad..
