Author Topic: AFN strange problem  (Read 3572 times)
August 21, 2010, 03:44:37 pm
oldskool rich
  • 446
AFN strange problem
« on: August 21, 2010, 03:44:37 pm »
ok so a mate brings me an A4, says its down on power, says he wants me to change the turbo, so i swap the GT15 for a GT17 as thats all i had knocking about, anyway the problem is still there, infact he says its much worse, its realy slow to rev, like it takes about 5 seconds to reach the red line wen reving in neutral, any ideas? i thort it cud be a boost leek but surly it wud still rev? cud be a colapsed cat but it runs the same with no down pipe, is there a sensor or vacuum pump that could cause this? why would it be worse with a GT17 i thort it would be better?
im out of answers, dont know much about the controls around the AFN, if anyone can help would be greatly appreciated
f6squared I.D.S.T
Reply #1August 22, 2010, 03:25:21 pm
rallydiesel
  • 1880
Re: AFN strange problem
« Reply #1 on: August 22, 2010, 03:25:21 pm »
Seems MAF-ish to me. Is AFN like a ALH? Sorry I don't have any more helpful advice.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2August 23, 2010, 02:04:08 am
oldskool rich
  • 446
« Reply #2 on: August 23, 2010, 02:04:08 am »
its 1Z, early TDI
why would having a better turbo make it slower?
f6squared I.D.S.T
Reply #3August 26, 2010, 09:18:09 pm
lucasone
  • 25
« Reply #3 on: August 26, 2010, 09:18:09 pm »
I agree, sound like a mass air flow sensor problem. The reason the GT17 would make less power is because a turbo spools up and makes boost based on how much exhaust is going through it. With a small amount of exhaust going through the manifold, the GT15 would actually spool up sooner and make more boost than the GT17. If you have a faulty MAF sensor the computer will only recognize a small amount of air going into the engine, so it will only allow your pump to inject a small amount of diesel. It's almost like you are giving 1/4 throttle.
Is the MIL light on? Do you have a scaner to check for codes? A faulty MAF sensor won't always set a code but if it does, then you know for sure that is your problem. Hope this helps, with out hearing or seeing the vehicle its hard to diagnose.
Cheers.
Reply #4August 30, 2010, 05:44:07 am
superspringer
  • 42
« Reply #4 on: August 30, 2010, 05:44:07 am »
Throttle position sensor mis reading?
