TDI Engine -General Info
mTDI
Topic: mTDI (Read 3705 times)
October 14, 2010, 03:53:05 pm
SR Heer
mTDI
October 14, 2010, 03:53:05 pm »
I have a Rover pump and may do a mTDI in Mk1 - Caddy.
To make thins fit as far as trany goes I was thinking of using the 5th (.71) gear of a late FN or FF and putting it in a
ASF, AON, ACN, ACL (8v) 3.67 3.45 1.94 1.37 1.03 0.75 trany - in order for it to be able to handle added HP and torque and yet fit without much modification - I do have the AHU's corresponding CTN tranny but it will require a modded cable shifting system and maybe mounts too.
Now for the clutch I was wanting to use the 210 flywheel - and maybe use a gasser one since it would be lighter - any comments or suggestions on this matter - also I will need a stout clutch to mate the two together - does anyone have any good recommendations for a 210 clutch that will not slip?
October 14, 2010, 04:56:12 pm
dieselherb1
Re: mTDI
October 14, 2010, 04:56:12 pm »
Seems you're doing the same as me, I don't have a Rover pump just a AAZ pump. I'm going to use a close ratio trans with a .071 fifth. Shpould be fun to drive and cruise well. People suggest using a 16 valve engine gas clutch. In the TDI cars I use VR6 clutch, last forever.
October 14, 2010, 05:29:45 pm
SR Heer
Re: mTDI
October 14, 2010, 05:29:45 pm »
But do you know if the VR6 clutch will fit on a 210mm flywheel - I don't know - did they make VR6s back in the 90s where the clutch and pressure plate fit the size and style of 210mm Mk2 flywheel?
October 15, 2010, 09:16:57 pm
Re: mTDI
October 15, 2010, 09:16:57 pm »
020 and 02a are completly different clutch set ups... replied in my m build thread..
also look for other guys post on here and vortex abt his adding a tdi to his mk1 jetta.. ive given him tons of info on tranny stuff this pas week.. along wth ac ino and such..
October 15, 2010, 09:40:12 pm
Re: mTDI
October 15, 2010, 09:40:12 pm »
MY swap thread
http://forums.vwvortex.com/showthread.php?4976461-Mk1-TDI-O2A-swap
mTDI
