Author Topic: 6 speed box will it fit mk2 golf  (Read 11057 times)
October 26, 2010, 01:35:45 pm
snakemaster
  • 405
« on: October 26, 2010, 01:35:45 pm »
i picked up this last week the box lookes to big to fit the mk2 golf with my 1z tdi  what do you guys think or could i swap 5th gear over  ???
Reply #1October 26, 2010, 05:00:44 pm
Re: 6 speed box will it fit mk2 golf
« Reply #1 on: October 26, 2010, 05:00:44 pm »
thats a PD TDI isnt it? its sexeh..
Reply #2October 28, 2010, 11:50:36 am
snakemaster
  • 405
« Reply #2 on: October 28, 2010, 11:50:36 am »
it shure is a pd  tdi 115hp
i think the box is a o2m   can any one shed some light on this
Reply #3October 28, 2010, 12:04:53 pm
smiffie88
  • 29
« Reply #3 on: October 28, 2010, 12:04:53 pm »
yeah box fits mk2 need to remake the two gearbox mounts and shorten the driveshafts you will also struggle with the speedo i think. theres a few guys done build threads on edition38 putting a pd and 6speed in a mk2
Reply #4October 30, 2010, 11:39:47 am
« Reply #4 on: October 30, 2010, 11:39:47 am »
everything mounts up completely different. it looks to me that it bolts in like a VR engine.. motor mounts bolted to the top of the frame horns..
and that trans has a jack shaft and equal length axles..
it would be ALOT of work, but most likely WORTH IT in the end.
Reply #5October 31, 2010, 11:14:19 pm
RadoTD
  • 513
    Stage WTF
« Reply #5 on: October 31, 2010, 11:14:19 pm »
I think the box is a o2m   can any one shed some light on this
I'm pretty sure you're right. They always look chubby and short.. IIRC o2j's still have the separate 5th/6th gear housing on the side where as the o2m has all the gears inside the case
@ the OP, you need to set up the hydraulic clutch, including newer pedal box, custom mounts and somehow mounting the shifter box inside the car. The mounting brackets are completely different for the o2m, so you need to fab up a way of mounting the shifter box in the right position too. I was looking into it before and if I remember right, that's all there is to it. Not easy, but far from impossible
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #6November 08, 2010, 11:23:52 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #6 on: November 08, 2010, 11:23:52 pm »
That looks the the unit from a Transporter. You might find that if you tried to put it in a golf, the gearbox would be at a weirdo angle. In the transporter, the engine tilts forwards, but teh gearbox still sits the same as the golf - different bellhousing bolt pattern.
'91 Golf Cabrio 1.9TD
Reply #7November 11, 2010, 05:41:02 am
« Reply #7 on: November 11, 2010, 05:41:02 am »
not like i am familiar with eurovan/transporter drivetrain, but i am familiar with the R/G/J drivetrain.. and now that you mention it, that engine IS tilted FORWARD!
Reply #8November 11, 2010, 01:42:10 pm
snakemaster
  • 405
« Reply #8 on: November 11, 2010, 01:42:10 pm »
the engine came out of  Seat Alhambra 1.9 TDi    http://www.autoolymp.sk/carimg/0/F/p0009412.jpg
Reply #9November 11, 2010, 01:47:55 pm
rallydiesel
  • 1880
« Reply #9 on: November 11, 2010, 01:47:55 pm »
Do all the 02M have a jackshaft? That's kind of neat. I didn't know vw trans' could have those.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #10November 11, 2010, 08:24:25 pm
Powered by Spearco
  • 1203
« Reply #10 on: November 11, 2010, 08:24:25 pm »
Euro Van had a jack shaft. There is a special mount to the back of the block that holds it. I know the trans is different sence it does not have a CV axle from it. They are the same 6spd but different bellhousing.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #11November 27, 2010, 08:00:22 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #11 on: November 27, 2010, 08:00:22 am »
fitting an 02M into a Mk2/corrado/mk3/b3/b4:
custom axles
custom mounting brackets
shifter, 2 options: custom mounting or sourcing rare european parts
K-Frame needs to have the transmount cup relocated
clutch line work
Here is a guy's outline of his process http://forums.vwvortex.com/showthread.php?2805002-Project-Build-sc2020
