Author Topic: ALH Build Up  (Read 4428 times)
December 08, 2010, 05:49:02 pm
catlin_cava
  • 1954
ALH Build Up
« on: December 08, 2010, 05:49:02 pm »
So...The turbo on my TDI Called it last night, All kinds of grinding noise, The Turbo speed goes up and down without the RPMS changing, Stopped Boosting  few weeks ago...I figured I can park it for the rest of the winter and kinna rebuild it lol. So here is the lis of stuff:
Looking at a VNT-22 Turbo
.205 or .216MM Injector Nozzles,
New Rings
Headgasket
ARP Studs
and Possibly a 11MM Head for the Pump.
Do I need to replace the Bearings on the Connecting Rods?
I'm only planning on Running 20PSI,
and I will be Changing the Clutch, Whats the best Combo
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1December 09, 2010, 04:06:56 pm
redneck_vdub
  • 80
Re: ALH Build Up
« Reply #1 on: December 09, 2010, 04:06:56 pm »
I'd replace all bearings and seals while your in there...well worth it, trust me. Plus if your going bigger nozzles, you'll probably need a programmer, cause stock fuel on a tdi isn't enough to put through the bigger nozzles, as I found out, and it'll spit and sputter. At least that's what I think is going on with mine, have to get some stock injectors to find out. Good luck!
'01 Golf TDI "The Redneck V-Dub"
360,000kms on the body; 17,000kms on the engine :D
EGR delete, 2.25" turbo back, air box mod, Giles injectors, VNT 17, ARP headstuds, 14LB flywheel, boost and EGT gauges.
Oo=w=oO
Reply #2December 09, 2010, 05:56:10 pm
catlin_cava
  • 1954
Re: ALH Build Up
« Reply #2 on: December 09, 2010, 05:56:10 pm »
I'm not pulling the motor, its staying in car, and I will be getting a software mod to work with everything I'm putting in
Catlin
Reply #3December 09, 2010, 07:45:31 pm
Re: ALH Build Up
« Reply #3 on: December 09, 2010, 07:45:31 pm »
catlin...you will be doing most of the engine and the clutch. It WILL be worth it do at least freshen the seals. The main seal does nasty things to new clutches and for probably less than 20.00 at least do that one for me LOL
I would plastigauge the bearings and see if you need them or not. If VW is still using one time use bolts then I would get new as the new bolts may cause the rods to need resized.
Reply #4December 11, 2010, 05:29:10 pm
Re: ALH Build Up
« Reply #4 on: December 11, 2010, 05:29:10 pm »
Luco-graggus I dunno if Catlin has talked to you or not, but pm him about your Unbrako Studs. ;)
Reply #5December 11, 2010, 06:16:30 pm
Re: ALH Build Up
« Reply #5 on: December 11, 2010, 06:16:30 pm »
I am an Unbrako STUD lol
If he needs them he can let me know. I don't want to be pushy :D
