Author Topic: 98 Jetta TDI eng. stuck  (Read 3540 times)
August 05, 2010, 06:22:22 pm
dieselherb1
  • 354
« on: August 05, 2010, 06:22:22 pm »
I'm listing this problem everywhere. 98 Jetta TDI running one day, turned off 3pm next day 6:30 am Click! Maybe battery dead,replace bat. nope. Rock the car in gear, nope. Try with a braker bar, nota. Took serp.TB loose, lifted cam up,no move! No lights or buzzers before shutdown. Pulled pan everthing looks cool. Going to seperate trans from eng. AM. Your thoughts.
Reply #1August 06, 2010, 06:20:17 am
fuslit
  • 118
Re: 98 Jetta TDI eng. stuck
« Reply #1 on: August 06, 2010, 06:20:17 am »
Did you check the starter before you started ripping things apart?
I've had multiple starters that had the woven copper cable between the solenoid and starter housing corrode through, Soldering in a new heavy duty cable solved the issue.
Hopefully your able to figure out what is going on with it without tearing things apart further.
-T
'81 rabbit 4dr 1.6TD [project]
'98 jetta tdi [daily]
Reply #2August 06, 2010, 07:43:07 pm
dieselherb1
  • 354
« Reply #2 on: August 06, 2010, 07:43:07 pm »
Yes, starter was first thing checked. This engine can not be turned with a 4 ft breaker bar. Next step remove main bearing caps. Every step costs money!
Reply #3August 06, 2010, 08:22:21 pm
« Reply #3 on: August 06, 2010, 08:22:21 pm »
Did your oil pump fail? and weld the pistons to the bores?
Reply #4September 03, 2010, 10:40:39 am
Redpawn
  • 24
« Reply #4 on: September 03, 2010, 10:40:39 am »
Did you try pulling the glow plugs? Mabey one of the injectors stuck open
and hydro locked the motor.
Reply #5September 03, 2010, 07:50:34 pm
dieselherb1
  • 354
« Reply #5 on: September 03, 2010, 07:50:34 pm »
I pulled the engine. Pulled the head there was some water in each cylinder. Even with head off can only turn the crank 3/4 turn. I will eventually find out why but for now I installed another engine.
