Author Topic: 2000 Jetta possible buy but vibrates consistent with RPMs  (Read 3269 times)
November 02, 2010, 10:04:10 am
SR Heer
  • 199
« on: November 02, 2010, 10:04:10 am »
I am looking into buying a 2000 Jetta that runs well - no blow-by when taking oil filler cap off - Jetta does have around 200,000 miles and it seems to vibrate extra hard and is consistent with frequency in relation to RPMs - the owner said it probably was the clutch system that needed to be changed out??? Does this sound reasonable? He said the clutches on these ALH motors was a two piece flywheel or split flywheel or something like that - can someone please elaborate - and please clue me in on what might go wrong with these clutches? And can sensed vibration be a symptom or condition of clutch problem or not?
Also what other things might I look at when looking at the 99.5 to 2003 years as far as things to check before buying - I have a 98 Jetta and am thinking of upgrading the clutch and turbo and injectors as well as tune and exhaust but if the 2000s are more upgrade friendly as far as tubos - etc then I will to wait until I get one before throwing extra bucks at a TDI. One advantage of the ALH Jettas is that their suspension and handling seemed to be quite a bit better than the AHU Jettas. Thanks for any input and or recommendations! Much appreciated!
Reply #1November 02, 2010, 11:42:35 am
  • 1739
Re: 2000 Jetta possible buy but vibrates consistent with RPMs
« Reply #1 on: November 02, 2010, 11:42:35 am »
Yes the later TDI's have a double plate pressure plate-known as dual mass. They wear and can get so bad they will vibrate at speed. Does it do while driven or when just reved?
make sure it's not a CV joint or driveshaft.The engine mount/torsion rod[ dog bone] that attaches the engine to the subframe can also break/wear to the point of letting the engine load/unload making it all shake. Either way, fixable.
In a way, the 99.5 up ECU's can be easier to "chip" because they just need to get flashed, where as the older ones literally get a chip replaced.
Reply #2November 02, 2010, 01:27:40 pm
catlin_cava
  • 1954
« Reply #2 on: November 02, 2010, 01:27:40 pm »
is the sound always constant or does it go away? and does it sound like its coming from the belt?
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #3November 02, 2010, 01:37:13 pm
SR Heer
  • 199
« Reply #3 on: November 02, 2010, 01:37:13 pm »
I am a vegetarian because I am a poor hunter ( :
No actually hopefully I will be able to go to Colorado for an elk hunt next year!
One elk lasts us two to three years and as far as lean - it is mean!!!
So glad my wife likes to both hunt and cook! (  :
ok - when taking the 2000 Jetta for a spin it seamed to vibrate when ever moving but yes it was consistent - did not vibrate harder or less and seamed to increase or decrease a bit in sync with auto speed so probably clutch - where is a good place to buy a complete clutch/flywheel set up? I would want to put a stage 2 or 3 clutch in like one for VR6 or something - since I may be wanting to upgrade with turbo later - question is - with my 98 Jetta a gt1756vb which as I understand can put out about 25lbs boost but does not fit well because of clearance tolerances there with motor mount to firewall area - is it easier to upgrade with ALH engines in that if I am not mistaken I think there may be more room for possible upgrade/larger turbos in that their exhaust manifold is one piece and the adapting or mounting may not be as critical there with them as compared to AHU Jettas - is this true or not necessarily - in other words if one had 2 grand to put into either their 98 AHU Jetta or 2000 ALH Jetta for performance upgrades which one could one get the most increase in HP for the buck spent? - What are some of the upgrade turbos that fit for the AHU engines and ALH engines? I have heard that the VT2256 rocks but one has to devise a good vane control mechanism??? Any ideas or links about such? Thanks!
« Last Edit: November 02, 2010, 02:00:57 pm by SR Heer »
Reply #4November 07, 2010, 03:26:46 pm
« Reply #4 on: November 07, 2010, 03:26:46 pm »
1756 VB anything like the 1749? integral manifold? my VNT will fit on mk1 and mk4 cars no problem.. mk2 and 3 cars pose a slight problem..
