Author Topic: GT15 on 1.6 shifter clearance problem  (Read 7317 times)
December 01, 2010, 08:24:16 pm
dieselherb1
  • 354
« on: December 01, 2010, 08:24:16 pm »
I put a GT15 turbo on a 1.6TD engine(really spools quick) but have a exhaust clearance problem with the shift rod(using part of the GT15 downpipe) Thought maybe shortening the shift rod? I tried a short shift adapter but still hits the exhaust.
Reply #1December 01, 2010, 08:27:20 pm
Re: GT15 on 1.6 shifter clearance problem
« Reply #1 on: December 01, 2010, 08:27:20 pm »
Maybe a tighter radius on the downpipe? Any pics?
Reply #2December 02, 2010, 08:07:29 am
« Reply #2 on: December 02, 2010, 08:07:29 am »
thats all it needs, a tighter radius. my downpipe has a real tight radius, and the shifter clears it by a mile. both 4 and  5 speed links clear my setup.
Reply #3December 03, 2010, 08:02:16 pm
dieselherb1
  • 354
« Reply #3 on: December 03, 2010, 08:02:16 pm »
What size and where did you get a tight radius pipe?
Reply #4December 04, 2010, 10:08:24 am
« Reply #4 on: December 04, 2010, 10:08:24 am »
i made my downpipe out of cut up chunks of exhaust pipe..
Reply #5December 04, 2010, 12:06:48 pm
« Reply #5 on: December 04, 2010, 12:06:48 pm »
summit racing has stainless and regular steel. I would use 2.5" or 3" with as short a radi as possible.
Reply #6December 04, 2010, 08:20:01 pm
dieselherb1
  • 354
« Reply #6 on: December 04, 2010, 08:20:01 pm »
The original DP from the TDI is pretty tight?
Reply #7December 04, 2010, 09:58:57 pm
81 vw pu
« Reply #7 on: December 04, 2010, 09:58:57 pm »
What chassis are we talking about?  My mk1 caddy was hella tight between the turbo and relay shaft lever. There was only about 2 inches between the turbo outlet and the relay shaft lever. The gt 15 looks identical to the generic turbo I used. I wanted to make a 2.5" or 3" downpipe but would have had to use a oval to round pipe adapter on the turbo outlet flange, which would make it even tighter yet. I ended up bending the top lever of the relay shaft down and ran my downpipe back towards the firewall and then down.
Reply #8December 05, 2010, 07:37:29 am
« Reply #8 on: December 05, 2010, 07:37:29 am »
Pic would be better for me to understand. I thought ROR just put 2 90 degree bends in his MK1
Reply #9December 05, 2010, 09:32:14 am
81 vw pu
« Reply #9 on: December 05, 2010, 09:32:14 am »
Here' a few pics of my downpipe in the caddy. This is with the shifter in 2nd gear.
view from drivers side
view from firewall
view from top
Reply #10December 05, 2010, 09:15:05 pm
dieselherb1
  • 354
« Reply #10 on: December 05, 2010, 09:15:05 pm »
With relay rod-shaft bent down it shifted okay? The original downpipe on the TDI is tight. The relay rod hits right in the middle of the pipe.
Reply #11December 05, 2010, 11:11:04 pm
81 vw pu
« Reply #11 on: December 05, 2010, 11:11:04 pm »
Yes it shifted the same with no adjustments. About all I used from the tdi downpipe was the flange.
This is what I started with, and cut the pipe off the flange.
And this is what I ended up with
Reply #12December 06, 2010, 05:51:32 am
dieselherb1
  • 354
« Reply #12 on: December 06, 2010, 05:51:32 am »
What-how did you regulate the wastegate? I put a boost gauge on mine and it hits 20-25 easy at 3000 rpm. Afraid I'll blow the HG without trying.
Reply #13December 06, 2010, 06:32:13 am
81 vw pu
« Reply #13 on: December 06, 2010, 06:32:13 am »
My wastegate has  a adjustable rod, but I left it where it was at around 10-11 psi.
Reply #14December 06, 2010, 10:21:23 am
« Reply #14 on: December 06, 2010, 10:21:23 am »
are we talking about GT conventional turbos? or GT VNTs? cause all my info pertains to a VNT.. and in a mk1 chassis..
and the reason you hit 30 psi by 3 grand is cause the vaines are not opening far enough, and the turbo is overspooling.
