Author Topic: GT15 on 1.6 shifter clearance problem  (Read 7281 times)
Reply #15December 06, 2010, 02:39:32 pm
81 vw pu
Re: GT15 on 1.6 shifter clearance problem
« Reply #15 on: December 06, 2010, 02:39:32 pm »
are we talking about GT conventional turbos? or GT VNTs? cause all my info pertains to a VNT.. and in a mk1 chassis..
and the reason you hit 30 psi by 3 grand is cause the vaines are not opening far enough, and the turbo is overspooling.
I'm talking about a non-Vnt in a mk1 chassis.
Reply #16December 06, 2010, 07:33:34 pm
dieselherb1
  • 354
« Reply #16 on: December 06, 2010, 07:33:34 pm »
Same here. A GT15 from a stock 98 Jetta 1z-AHU engine. Mine has a solenoid either vacuum or pressure controled.
Reply #17December 07, 2010, 10:57:17 am
« Reply #17 on: December 07, 2010, 10:57:17 am »
oh, well im basically useless now..i have ZERO experience with a GT15 conventional..
Reply #18December 07, 2010, 11:42:57 am
81 vw pu
« Reply #18 on: December 07, 2010, 11:42:57 am »
Here is a pic of my turbo. You can see the wastegate actuator between the turbo and the block.
The actuator recieves pressure from the turbo to open the internal wastegate.
Reply #19December 07, 2010, 12:52:56 pm
« Reply #19 on: December 07, 2010, 12:52:56 pm »
i really hope that intake tube is just for mock up purposes..
if you use billows hose like that, it will restrict the turbo so bad.. use as big of a feed for the turbo inlet as you POSSIBLY can.
