General Information
» Upgrades (non engine related )
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
Rev counter powered from hall type sensor?
13" wheels - What offset for a stock Mk1 is the limit?
HELP: Axle shaft outer bearing clearance issues, 80 caddy
Center Console holes
Short shifter
Lightened flywheel
Adding AC
Auber EGT
Nuespeed strut tower brace
Would an Audi front wheel hub fit on a Golf 2?
turbo diesel VOLKSYOTA/TOYWAGEN
Is there any difference between suspension between AAZ and AHU?
Autometer fuel level gauge
82 Caddy 1.6 NA diesel manual steering rack question
Torque Wrenches?
So I repaired my dash...(just the bad spot)
Cruise Control
large tire diameter on 82 westy
slight rust problem
Wheel clearance + opinions
Cabriolet Dash in Rabbit
Brakes
Eibach Springs vs JOM coilovers
Mk2 suspension rebuild parts on the cheap
My car the only AAZ in my area!
please help me open the door!
Repacking CV Joints
So where does one find a center console?
Mk1 grille on a Mk2
Rubber peg under accelerator pedal (does it serve a purpose?)
Gauge Cluster Mission - Where to find another (besides junkyard)
City Lights
Dash cross-over compatibility
MK II Radiator Fan Install MKI Caddy
.68 5th
dakota digital tach converter in a 86 cabriolet
Bags or struts that go higher than stock
Prothe door handles
Gauges for Diesel VW Beetle baja
Wiring to rear door/trim removal
Desireable transmission
Springs
Diesel Gearboxes for the mk3 Golf?
door card fabric
Heated Seats
mk2/mk3 suspension
wheels, corrado 4x100 brakes (11"?)
MK1 Jetta Dash Install To MK1 Caddy
can you put mk2 suspension in a mk1?
MKII wiper delay mod
