Author Topic: Heated Seats  (Read 3550 times)
February 19, 2011, 09:50:45 pm
  • 3468
    • McScrubbins Body Wash
Heated Seats
« on: February 19, 2011, 09:50:45 pm »
I have a switch from an MK2 for heated seats.
The one with two rolling dials that go from 0-5. im just wondering if anyone has a resource or knows of the particulars of the pins on it. I can easily make a wiring harness for it, as the pins are a standard size for female crimp on fittings. I just need to know some info on the pins. I've looked for numbers on them but i couldn't see anything.
Reply #1February 19, 2011, 09:53:05 pm
Quantum TD
  • 1195
Re: Heated Seats
« Reply #1 on: February 19, 2011, 09:53:05 pm »
A lot of the plugs, wiring, relays and elements are the same for all MK3, MK4 and B3/B4. You could probably get some bits from a Passat or Corrado and make it work. That's my plan.
Reply #2February 19, 2011, 09:54:55 pm
  • 3468
Re: Heated Seats
« Reply #2 on: February 19, 2011, 09:54:55 pm »
ooooooo I see i seeeeeeee Good to know! speedy reply too!
Reply #3February 19, 2011, 09:55:24 pm
  • 3468
Re: Heated Seats
« Reply #3 on: February 19, 2011, 09:55:24 pm »
I guess i'll try and rip a complete system from a car in the junk yard.
Reply #4February 19, 2011, 10:59:32 pm
RadoTD
  • 513
    Stage WTF
Re: Heated Seats
« Reply #4 on: February 19, 2011, 10:59:32 pm »
http://forums.vwvortex.com/showthread.php?2988358-DIY-Heated-seats-for-cars-not-pre-wired!!
Shazam
The above schematic does NOT use the thermostat in the seats through the switch!
In an OEM setup, you've got the switch, which I think is just a rheostat, then a pair of relays behind the passenger rear door card that have some clicky action and a bit of magic inside them, then on the seat is a 6pin connector. +/- for back heater, +/- for butt heater, then the third pair of pins is for a thermistor that, along with the switch in the dash makes the fancy relays go clicky click.
I believe you're still planning on using aftermarket seat heaters? Make sure that first they have built in thermistors or something else along those lines and second, that with the switch you have, the resistance is low enough to get enough voltage through to trigger the relay. Don't run your power straight through the switch, it'll probably burn it out.
A few more things I just noticed about the schematic in the link up top, the relay, "30 unswitched power" is constant 12V, and "75x switched power" is your load reduction relay. I wouldn't worry about it running through your load reduction relay, just shut them off for a cold start, but I would run them off of the ignition so that you can just normally leave the seats on all the time
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #5February 22, 2011, 06:05:41 pm
Thezorn
  • 381
Re: Heated Seats
« Reply #5 on: February 22, 2011, 06:05:41 pm »
Shazam
YEEEESSSSSSSS!!!! just about to get some mk4 heated leathers and this is exactlly what I need Perfect timing
Compounded 93 AAZ
