General Information
» Upgrades (non engine related )
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
Aftermarket Tach reads too high.
Turned up fuel on 1.6td
Growl when lifting off the accelerator pedal - whatzit?
Swapping 84 Cabby Wing Windows and Gaskets to 81 Rabbit, Can it be done?
02A Transmission Sealant
diy airbox for my mk1 ver. 1.0
Intercooler from 2.4 td PT Cruiser
What tank would i need in my b3 to use a mk3 sender....
Oil change, better v-belt setup and door seals. MK1 content
adding hydro/02a to a mk2?? look here
brake booster
Will they fit or be useless
Stiffening stock front springs on my b3...?
Ecode headlamps in mk3 jetta with Intercooler.
VW Caddy Bedrug ( another option for a liner )
VW Caddy Rear Window Seal ( Replacement )
New Seats for Caddy
MK2 Dash Lights -> LED
crome trim on the bottem side of my caddy at rocker pannel
Build Thread for Rudy Rabbit - 1977 1.5na to 1.6na and everything in between
Front seat swap question.
Cheap low flow muffler\resonator?
MK1 SUSPENSION INTO MK2.... Why not?
Floor mats
Don't like the transmission in my mk2 Eco diesel
Scirocco to mk1 parts
caddy bench seat?
Fuel Tank Sending Units - Modern Upgrade...
Is this the same as...
Weekend project..
Smoke stacks!
Mk1 Engine out - stuff to change or check?
O2a to O2j shifter conversion..
K&N Cone Air Filter.
Possibly dumb GTI valence/Caddy question..
changing MK1 Caddy to Mk 2 master cylinder
AAZ in Mk1 Caddy with Air Conditioning
mk1 top alt belt idler
any success with non VW seats installed?
mk1 solid rotors to ventilated ones (GTI)
Gold in the BoneYard
Where do you buy your shifter bushings, bearings and misc parts??
Power steering removal?
proper tire size for 15"rim on a mk3 TD to maintain accurate speedometer?
help with tacho on passat 35i(to lower rpm signal)
aaz cam caps and valve cover on 1.6?
cigarette lighter
Mk 2 floor matts
Fix Headliner?
self lubricating starter bushing
