Author Topic: mk1 solid rotors to ventilated ones (GTI)  (Read 11103 times)
January 05, 2013, 10:30:53 am
homerj1
  • 433
« on: January 05, 2013, 10:30:53 am »
I might need to refurbish the front brakes of my 84 Jetta.
They are currently solid rotors,
  Can I buy and installed   84 gti, ventilated calipers, rotosr and pads, AND will they bolt in,,,,
thanks
Reply #1January 05, 2013, 11:53:08 am
Re: mk1 solid rotors to ventilated ones (GTI)
« Reply #1 on: January 05, 2013, 11:53:08 am »
1/2 worn solid pads, or new vented pads, and rotors all you need... same caliper... they just made the pad 1/2 as thick...
Reply #2January 05, 2013, 01:14:04 pm
« Reply #2 on: January 05, 2013, 01:14:04 pm »
The last time I bought pads (for a vented rotor car of this era) they did not ask me what kind of rotors I had. I'm thinking that (at least some) manufacturers may have consolidated the product line and stopped offering 2 of the same pads, the only difference being the thickness of the friction material, and only offer the thinner type (which corresponds to the thicker vented rotors but can be used on both).
Basically, there's no reason not to be using vented rotors, and I would get cross-drilled ones too because they aren't terribly expensive for these cars.
Reply #3January 05, 2013, 03:40:01 pm
« Reply #3 on: January 05, 2013, 03:40:01 pm »
No need to change calipers. Just buy mk1 16v vented rotors, 239x12 iirc and some vented pads.
edit: typo error
« Last Edit: January 05, 2013, 07:32:58 pm by 8v-of-fury »
Reply #4January 05, 2013, 07:27:08 pm
« Reply #4 on: January 05, 2013, 07:27:08 pm »
 just get normal 8v gti brake rotors... 83-89.... in 88 the gti became a gt... gti all had 16v... in 90ish gti got 10.1" fronts like jetta did in 88..
« Last Edit: January 05, 2013, 07:33:10 pm by 8v-of-fury »
Reply #5January 05, 2013, 07:33:34 pm
« Reply #5 on: January 05, 2013, 07:33:34 pm »
Basically just a 239x12 as opposed to 239x20.
Reply #6January 06, 2013, 12:18:07 am
« Reply #6 on: January 06, 2013, 12:18:07 am »
no.... why edit it.. now you still gotta fix your post... again... what you removed from mine messes it up..
16v mk1 = 16v rocco = 10.1" requires all kinds of crap...
8v gti/gli.... 9.4" vented rotors...
i use solid on winter car... vented cool off too fast in slushy cold puddles... brakes have to warm up to work... if you have run both on a mk1 winter slush you can feel the differance..
Reply #7January 06, 2013, 02:46:27 am
homerj1
  • 433
« Reply #7 on: January 06, 2013, 02:46:27 am »
Thanks, for the help, you guys are a wealth of knowledge!
Now, if I wanted to make  Chicken Cordon Bleu covered in a raspberry glaze........  lol
Reply #8January 06, 2013, 09:46:43 am
« Reply #8 on: January 06, 2013, 09:46:43 am »
Seems like we'd come to you on that one Aivars ;)
Reply #9January 06, 2013, 11:11:48 am
homerj1
  • 433
« Reply #9 on: January 06, 2013, 11:11:48 am »
Reply #10January 06, 2013, 12:38:50 pm
« Reply #10 on: January 06, 2013, 12:38:50 pm »
Visit the Cooking Channel, Our oil is for diesels only.
Reply #11January 06, 2013, 12:43:26 pm
« Reply #11 on: January 06, 2013, 12:43:26 pm »
HAHA No offense intended.. just you already knew what it was called! I wouldn't have a clue lol.
Reply #12January 07, 2013, 02:53:17 pm
homerj1
  • 433
« Reply #12 on: January 07, 2013, 02:53:17 pm »
lol - none taken,  Actually, I don't even know what it is?  But I do make a mean tabbouleh.
Reply #13January 25, 2013, 10:51:58 am
« Reply #13 on: January 25, 2013, 10:51:58 am »
take a chicken breast, butter fly it, stuff it with ham and swiss cheese,, bread it, and fry it..
Reply #14February 01, 2013, 07:10:43 am
vwsb1974
  • 81
« Reply #14 on: February 01, 2013, 07:10:43 am »
I need to replace the front brakes on my 89 jetta they are currently solid can I do the same thing. From what I have been reading I can. I will be replacing the calipers at the same time. Do I stay with stock of change the whole thing to GTI stuff. I have 13" wheels
