Author Topic: Aftermarket Tach reads too high.  (Read 4711 times)
July 21, 2013, 01:10:14 pm
homerj1
  • 433
« on: July 21, 2013, 01:10:14 pm »
Just installed one of these to my w terminal ( 1.6td)
http://www.ebay.com/itm/60MM-Stepper-Motor-DIESEL-TACHOMETER-RPM-GAUGE-METER-/220704701680?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3363067cf0
After tweaking adjustments on the tach  it still reads 25% too high - no big deal at idle - but when 4000 rpm is really 3000.   ???
I installed a 47 K variable resistor ( from a mk3 3 light switch) in the w terminal line to the tach - but no real change.
Do I need a stronger\heavier variable resistor?  The local Radio Shack has only packs of resistors.
Can I steal something from another electrical device?  I was even eyeballing the pedal control on our sewing machine.   ;D ;D
Reply #1July 21, 2013, 01:30:46 pm
Re: Aftermarket Tach reads too high.
« Reply #1 on: July 21, 2013, 01:30:46 pm »
This Kit arrived With All Necessary Hardware's Including:
·      Gauge
·      Manual English Installation instruction
I think this says everything you need to know
but maybe a magnet trigger on the crank pulley...
Reply #2July 21, 2013, 01:38:25 pm
homerj1
  • 433
« Reply #2 on: July 21, 2013, 01:38:25 pm »
·      Gauge
lol,
Maybe they were just having a bad english translation day. ;)
I know I should have spent more $$$$ or tried a gasser conversion.
But I'm still thinking a variable resistor would work -or I can hone my math skill by subtracting 25%. I do have time, as the 010 trans does all the shifting.   :-[
Reply #3July 21, 2013, 02:17:44 pm
homerj1
  • 433
« Reply #3 on: July 21, 2013, 02:17:44 pm »
·      Gauge
lol,
Doh!!
Variable resistor will only work in the tach - not the signal from the W terminal - as this signal is in pulses.  Damn you Kahn!!!!    http://www.youtube.com/watch?v=LTMI6v9NyJg
Here I go,    3000rpm - 25% =  2250rpm,  4000 - 25% = ........
« Last Edit: July 21, 2013, 02:26:54 pm by homerj1 »
Reply #4July 22, 2013, 12:08:12 am
« Reply #4 on: July 22, 2013, 12:08:12 am »
Dakota Digital SGI 5
