View full version: Upgrades (non engine related )
« 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 »
  1. 85 jetta build
  2. Rear Discs brakes from a corrado onto an MKII?
  3. My subframe is broke, anyone else have a bad VW day?
  4. Vanagon Convex Heated Manual Mirrors
  5. Transmission Ratio's and other assorted anomalies... ?
  6. front end suspention "rattle" Help Please
  7. lowest cruise speed setting
  8. 83' Vanagon window washer/wiper intermittent/interval relay
  9. Boost gauge question
  10. vacume pump repair???
  11. Gauge overlays
  12. Air Conditioning questions
  13. Direct-Shift Gearbox :?:
  14. If you've stripped a bolt/screw etc...
  15. 82 Jetta Heater
  16. Bosch alternator bearing codes
  17. new jetta heater or lack of!!!!
  18. short throw shifter
  19. hope this is the right section ALTERNATOR upgrades for 1.6TD
  20. littel slow on forum, so weather talk.
  21. Stuck cv bolts
  22. Who's done it?
  23. Mk2 Tachometer into a Mk1 Caddy
  24. MK2 crash safety
  25. heated seat upgrade in my caddy. need wireing info.
  26. Gasser clutch on 1.6?
  27. 98 GTI seats in my A2?
  28. Interior upgraded/Lower stance PICS!!!
  29. 5-speed gearbox into a T3 TD Vanagon
  30. Proportioning valve or pressure reducing valve
  31. b3 passat cluster in a 91 jetta td?
  32. Bed Liner for Floor Protection
  33. MK2 tranny into a MK1
  34. Blower motor switch question
  35. Heavy duty springs for rear draggin' bunny's.
  36. guage pods
  37. rpl rear stabilizer bushings
  38. Torx
  39. Passat Seats
  40. Will the manual steering rack fit...
  41. Converting a new beetle to mechanical steering?
  42. A/C installation instructions for 1981 1.6 Turbo Caddy
  43. Rear struts Mk3 Jetta
  44. a/c delete, 2 alternators?
  45. Sprung vs Solid clutch discs?
  46. rally car!!
  47. Exhaust
  48. disc brakes on an '85?
  49. caddy carpet
  50. Strut Tower Rusted Through HELP!!!
