Author Topic: Boost gauge question  (Read 3942 times)
February 07, 2009, 08:29:47 pm
Jettage1
  • 202
    Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
« on: February 07, 2009, 08:29:47 pm »
I just finished installing a VDO boost gauge.  Seems to make a slight buzzing noise, mostly when off-throttle (idle or coasting).  I checked my tube connections & they are tight.  The sound seems to come from within the gauge.  Is this just normal operating behavior for a boost gauge?  I don't have any reference point...
Thanks!
P.S. Putting out 11-12 psi with K14 & Giles pump.  Stock 2" exhaust (cat removed).
Steve
92 Jetta EcoDiesel
     pumped by Giles...powered by Frybrid...functional by dumb luck
Reply #1February 09, 2009, 04:06:52 pm
Jettage1
  • 202
« Reply #1 on: February 09, 2009, 04:06:52 pm »
Any input?  This thing is making me crazy (as if the engine wasn't loud enough already).  The sound is kind of tinny / sounds like someone swiping a nail across a small loose spring...
Normal?  Or do I need to take it up with the store I bought it from?
TIA...
Steve
92 Jetta EcoDiesel
Reply #2February 09, 2009, 06:15:17 pm
AudiVWguy
« Reply #2 on: February 09, 2009, 06:15:17 pm »
All the boost gauges I've owned have been silent. Tell the company it's defective.
Reply #3February 09, 2009, 06:52:16 pm
truckinwagen
  • 1895
« Reply #3 on: February 09, 2009, 06:52:16 pm »
mechanical boost gauges often buzz, you can try putting a restriction in the line going to it, that is supposed to help.
83 Opel Kadett Diesel
Reply #4February 09, 2009, 06:57:20 pm
Jettage1
  • 202
« Reply #4 on: February 09, 2009, 06:57:20 pm »
Quote from: "truckinwagen"
Hmmm... like pinching the rubber hose?  (I'm using rubber vac line for about a foot from the tee, then it goes to the hard plastic stuff for the rest of the trip.)  I'll try a clothespin as an experiment maybe.
Thanks for the idea!
If that fails, then it's back to the store!
Steve
92 Jetta EcoDiesel
Reply #5February 09, 2009, 07:51:12 pm
« Reply #5 on: February 09, 2009, 07:51:12 pm »
i've used one of those little water valves to restrict them before.
bought it from the local Napa parts store.
That buzzing is nasty huh?
Reply #6February 09, 2009, 08:17:48 pm
« Reply #6 on: February 09, 2009, 08:17:48 pm »
Various manufacturers sell a boost gauge tee with a built-in restriction for this *exact* reason.
There's one about 3/4 down this page, for example:
http://www.concept1.ca/engine%20gauges.htm
Killed the buzz in my gauge immediately, with no noticeable increase in lag.
Reply #7February 10, 2009, 04:53:47 am
Jettage1
  • 202
« Reply #7 on: February 10, 2009, 04:53:47 am »
Tried the clothespin this morning.  Initially no difference, but once the car warmed up I think the line softened a bit more and I ended up with little to no buzz.  Hallelujah!
Thanks Vince & Dan for the ideas!  I have an old brass aquarium air line valve I could probably use, but I'd be afraid it would be constantly vibrating open.  Think I'll go the tee route.
I love this forum!   :D
Steve
92 Jetta EcoDiesel
