Author Topic: Rear Discs brakes from a corrado onto an MKII?  (Read 8157 times)
February 08, 2009, 07:53:13 am
Torchd
  • 372
« on: February 08, 2009, 07:53:13 am »
Hey guys!
I have heard that the whole rear axle beam removed from a corrado can be fitted to an MKII golf with the disc brakes and every thing?
Is that true? What other parts would be required?
Thanks.
Reply #1February 09, 2009, 06:25:01 pm
AudiVWguy
« Reply #1 on: February 09, 2009, 06:25:01 pm »
Get out yer tape measure to make sure the width and pivot points are the same. Take pictures of brake line routing to compare.
Other wise, you can just unbolt the pieces that hold the old stuff and bolt on the new parts. Doing the whole rear section would be the better way to go if everything matches up.
-JB
Reply #2February 09, 2009, 06:30:39 pm
truckinwagen
  • 1895
« Reply #2 on: February 09, 2009, 06:30:39 pm »
should fit, if the whole rear beam does not, then you can swap the discs to your beam, the stub axles will bolt up, just did that swap on my rabbit
83 Opel Kadett Diesel
Reply #3February 10, 2009, 08:00:14 am
foxracer1
  • 991
« Reply #3 on: February 10, 2009, 08:00:14 am »
I have a jetta III axle under my MKII jetta. Its about 3/4" wider at the flanges on each side. Every thing bolts up the same. My friend has a corrado axle under his MKII jetta. Fits just fine. Has a bigger sway bar built in to the beam. Do it!
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #4February 11, 2009, 02:14:09 am
Torchd
  • 372
« Reply #4 on: February 11, 2009, 02:14:09 am »
Thanks....  what hand brake cables will I be using? I was told cable from the MKII GTI will fit no problems... is that true?
Reply #5February 11, 2009, 02:36:53 am
  • 3468
    • McScrubbins Body Wash
« Reply #5 on: February 11, 2009, 02:36:53 am »
Fox, do your rear tires stick out wider than normal then?
Reply #6February 11, 2009, 06:30:23 am
foxracer1
  • 991
« Reply #6 on: February 11, 2009, 06:30:23 am »
Yeah GTI cables will work. I had to use early MKII (85-87) jetta w/disc cables.
Yeah slightly. They still tuck under the wheel wells with the tall skinny tires i have now. Haven't tried any wider wheels. Also i have 1st gen passat control arms up front with MKIII 100mm cv axles. They stick out noticeably. Once again not much rubbing with my current tire setup. 185/70-14  Looks good though.
91 S10 305 TPI T56
Reply #7February 18, 2009, 09:01:35 am
Torchd
  • 372
« Reply #7 on: February 18, 2009, 09:01:35 am »
seen... thanks guys!
Reply #8February 18, 2009, 09:03:07 am
« Reply #8 on: February 18, 2009, 09:03:07 am »
I'm a bit late here but Passat rears bolt right up to your mk2 axle.
Reply #9February 18, 2009, 09:06:27 pm
Torchd
  • 372
« Reply #9 on: February 18, 2009, 09:06:27 pm »
Which Passat?
Reply #10February 20, 2009, 08:15:51 pm
Torchd
  • 372
« Reply #10 on: February 20, 2009, 08:15:51 pm »
ZUKGOD1... which passat??
Reply #11February 20, 2009, 11:42:04 pm
foxracer1
  • 991
« Reply #11 on: February 20, 2009, 11:42:04 pm »
Any passat will bolt on but some had 5 lug didn't they? That gets complicated cause then you have to do the front hubs.
91 S10 305 TPI T56
Reply #12February 21, 2009, 08:12:42 pm
« Reply #12 on: February 21, 2009, 08:12:42 pm »
Sorry I forgot to subscribe so I didn't see it was still an on going conversation.
The Passat I used was a mid 90's 4 lug.
All Passat rear disc's are the same I believe up until they switched to 5 lugs, then things got moved around a bit.
Reply #13February 22, 2009, 08:28:34 am
Torchd
  • 372
« Reply #13 on: February 22, 2009, 08:28:34 am »
Hmm... Thanks zukgod. I will start looking for a passat rear axle, hopefully it should be easier to find!
Reply #14February 22, 2009, 09:03:53 am
« Reply #14 on: February 22, 2009, 09:03:53 am »
There are usually a few Passats in our local yards. from what I remember there are a couple bolts that have a Allen head. kinda hrd to remove.
get the brakes, spindals, parking brake cables, and if you can the hard lines on the rear axles if not though yours will work.
