View full version: Upgrades (non engine related )
« 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 »
  1. Where to find quality mk1 upper strut mounts
  2. Lowering and improving handling of Mk1 Jetta.
  3. O2a 6 speed conversion
  4. Brake upgrade tips?
  5. Motor mounts
  6. Rear Springs
  7. Lets talk Vent windows
  8. Emblem Restoration
  9. Intercooler Install , VW Rabbit Truck MKI
  10. KYB Caddy rear shocks - STIFF!
  11. MkII 020 in a MkI: will it fit?
  12. missing linkz shift rod bearing and other shifter upgrades
  13. 80% peloquin shim kit
  14. Adding Wheel/Fender Flares to my 1980 caddy
  15. Suspension Upgrades mk2
  16. 16v Pressure plate & Flywheel, 8v Friction disc
  17. MK1's and the ACN - AON - ASF - ACL 020 VW Trans
  18. Spring Rates For Mk1 Jetta
  19. Electric fuel pump questions.
  20. will 84 jetta dash fit in my 83 rabbit mk 1
  21. Master Cylinder Upgrade
  22. I need a 210mm flywheel WITH TDC mark!
  23. Mk 2 coil overs
  24. Repaired Cruise control
  25. Repaired odometer
  26. Series one revcounter/tacho converted to diesel
  27. 2001 Jetta Glove box
  28. M-TDI Transmission Discussion
  29. Can I make my mk3 calipers work on my mk1?
  30. AAZ and 92 Golf 1.8L (8v) flywheel
  31. MK1 Disc Brakes?
  32. A3 golf Fuse
  33. Changing 4th gear?
  34. mk1 aaz air conditioning and radiator
  35. Best way to clean seats?
  36. mk1/2 pedal cluster
  37. READ THIS FIRST - FAQ Quick guide for commonly asked questions
  38. 020 ASF .75 and 3.67, need any taller then that for highway diesel?
  39. Anyone purchased and installed a peloquin on a 020?
  40. Need help with Caddy sway bar install; got pix?
  41. Engines out. Manual rack should i???
  42. DIY Self drilled Brembo rotors
  43. Rack and Pinion ????
  44. Late Mk2 Steering Knuckle/ Hub
  45. Molded, shell-type Mk2 headliner in an 83 Rabbit?
  46. Engine Mounts MK1 source
  47. Rabbit pedal cluster ..... Help !
  48. 89 golf outer cv gone. Fix or replace? Help please
  49. No Brakes!
  50. Any benifit to a 5 speed upgrade?
