Author Topic: Molded, shell-type Mk2 headliner in an 83 Rabbit?  (Read 3930 times)
June 06, 2012, 05:31:56 pm
Blocksmith
  • 261
    Wrench Lurker
« on: June 06, 2012, 05:31:56 pm »
Title says it all--is there any chance they're cross compatible? Need to redo the headliner in my bunny, and I figured a mk2 style would be an upgrade, and be simpler as well. Anyone tried it?
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #1June 06, 2012, 07:55:23 pm
Re: Molded, shell-type Mk2 headliner in an 83 Rabbit?
« Reply #1 on: June 06, 2012, 07:55:23 pm »
Considering the roof lines are nearly completely different, it would probably be a lot of work unfortunately.
It is definitely not a bolt in affair.
Reply #2June 06, 2012, 08:07:49 pm
CrazyAndy
  • 739
« Reply #2 on: June 06, 2012, 08:07:49 pm »
Yeah I had to do my whole damn headliner about 2 years ago.
Link to threads:
Pt1:http://www.the152.com/modules.php?name=Forums&file=viewtopic&p=71006&highlight=#71006
Pt2:http://www.the152.com/modules.php?name=Forums&file=viewtopic&p=71027&highlight=#71027
Pics still work an' errythin.  SO since you can't swap a molded headliner in , at least take that link as a consolation.
« Last Edit: June 06, 2012, 08:11:03 pm by CrazyAndy »
Reply #3June 07, 2012, 06:47:19 am
Blocksmith
  • 261
    Wrench Lurker
« Reply #3 on: June 07, 2012, 06:47:19 am »
Okay, that's honestly what I expected, that it wouldn't work; thought I'd ask anyway just to make sure.
CrazyAndy---that was an excellent thread! The more pics, the better, I always say. I think we need to make it a sticky link in the FAQ/how-to section.
Reply #4June 09, 2012, 11:52:15 am
« Reply #4 on: June 09, 2012, 11:52:15 am »
I would honestly prefer the earlier style headliner fabric headliner. The headliners can be re-lined but once the moulded one starts to crack, I think it's done.
I have a friend who does headliners, it looks easy. He uses a toilet cleaning brush attached to an electric drill to knock all the residual foam off the cardboard backing. The foam-backed fabric is available at Jo Ann Fabrics. Use the 3M heavy spray adhesive for "heavy headliners," that's exactly what it says on the can, I think NAPA has it. It's like $25 for one can but the light duty stuff does not last.
Reply #5June 13, 2012, 09:39:47 am
CrazyAndy
  • 739
« Reply #5 on: June 13, 2012, 09:39:47 am »
Thanks for the praise!  I made it a point to take as many pics a spossible for visual learners.  Although I would think about using the spray adhesive that bajacalal mentioned; my headliner is starting to pull off where the cardboard bends are.  Still was a lot of fun and lasted bretty well for about 2 or so years.
