Author Topic: Anyone purchased and installed a peloquin on a 020?  (Read 8652 times)
May 31, 2012, 05:21:42 pm
  • 3468
    • McScrubbins Body Wash
« on: May 31, 2012, 05:21:42 pm »
My jetta was useless in the snow at the ski hill this past season not because of my tires but because it was so incredibly difficult not to spin 1 tire at a time.
The snow tires helped a lot but i just hated the fact that i couldn't make the front tires like a possi on a RWD car! :P
The suggested retail price on these make me cringe but has anyone actually done this and could shed some light for me?
http://www.peloquins.com/products_020.html
Reply #1May 31, 2012, 05:54:21 pm
Re: Anyone purchased and installed a peloquin on a 020?
« Reply #1 on: May 31, 2012, 05:54:21 pm »
ive used the poor-mans posi before, and lightly rode the brakes, to keep it from biasing one side soo bad..
Reply #2May 31, 2012, 06:25:37 pm
  • 3468
« Reply #2 on: May 31, 2012, 06:25:37 pm »
Sounds tricky for snowy conditions...
Reply #3May 31, 2012, 06:30:56 pm
« Reply #3 on: May 31, 2012, 06:30:56 pm »
thats the only time i ever use that trick. either on snow/ice or mud. and my car doesnt see much mud action.
Reply #4May 31, 2012, 11:28:39 pm
mystery3
  • 774
« Reply #4 on: May 31, 2012, 11:28:39 pm »
I think the quaife units are a little more reasonably priced but I don't know much about the different setups, peloquin, quaife or wavetrac.
Reply #5May 31, 2012, 11:46:23 pm
  • 3468
« Reply #5 on: May 31, 2012, 11:46:23 pm »
It would be cheaper (but not easier) to find an AWD set up from an audi that bolts up. doesnt a quattro fit most 4 door mk2s?
Reply #6May 31, 2012, 11:57:36 pm
mystery3
  • 774
« Reply #6 on: May 31, 2012, 11:57:36 pm »
If this were the case there would be 1000's of awd mkII's on the road in this country. It's an engineering/fabrication nightmare, no easy solution, it'd be much easier to swap the diesel into a 4000 or something.
Reply #7June 01, 2012, 06:16:13 am
« Reply #7 on: June 01, 2012, 06:16:13 am »
http://www.peloquins.com/products_80.html
same website different product. This is what I had in mine. It is a much cheaper and easier solution to try. VW never had anywhere close to the 80% I think the most they did was 20%. At any rate that is what I used in mine and it helped a ton. In the mud with around 40,000 miles it would still spin 2 tires. Brokevw says there is nothing wrong with the kit and he has used them in his own cars. It is easy to install, just about like doing the flange seals. The Peloquin you have to strip the entire case and setup the ring and pinion gears as the peloquin takes the place of the ring gear carrier.
Reply #8June 01, 2012, 10:41:57 am
rallydiesel
  • 1880
« Reply #8 on: June 01, 2012, 10:41:57 am »
I wouldn't spend the money on a LSD if it was going into an 020. If you really want an LSD, convert to a 02a.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #9June 01, 2012, 10:50:58 am
« Reply #9 on: June 01, 2012, 10:50:58 am »
x2..
if your gonna drop the coin on LSD, then just get an O2A..
if you have enough power/torque to warrant a LSD, then you probably aint far from the limits of the 020 trans..
i know that the next upgrade im doing to my car, is an O2A trans swap..
Reply #10June 01, 2012, 02:50:22 pm
« Reply #10 on: June 01, 2012, 02:50:22 pm »
From what broke vw said the wavetrack in theory was the "best" setup, but they had issues with the hardening process. They would shear the machined portion off of the arp bolts so they couldn't be tightend properly. He contacted them and they said they were addressing the issue.
Reply #11June 05, 2012, 01:46:53 pm
Henk
  • 111
« Reply #11 on: June 05, 2012, 01:46:53 pm »
On a bit of a threadjack, but is any kind of LSD available for 02a/j?
would the 020 transaxle go in an 02a?
Had thought of putting an 80% diff in mine but they're so damn pricey
Mid Engine
Berg Cup
M-TDi
Caddy!
Reply #12June 05, 2012, 02:37:53 pm
« Reply #12 on: June 05, 2012, 02:37:53 pm »
Same are available as far as I know.
80% is less than 100.00 USD...that is cheap IMHO
Reply #13June 05, 2012, 07:15:39 pm
ToddA1
  • 434
« Reply #13 on: June 05, 2012, 07:15:39 pm »
I've owned a few Quaifes and they work fine.  Jumping on the throttle from a slow roll still had some evil torque steer.  The Peloquin works pretty much the same as the Quaife.  Peloquin also includes the diff bearings and bolts.  The Peloquin also has a much better warranty.
I've also used the 80% shim kit and was able to do 2 wheeled burn outs.  The shim kits do wear out, so be aware of that.
-Todd
Reply #14June 07, 2012, 09:57:08 am
« Reply #14 on: June 07, 2012, 09:57:08 am »
thats not a LSD tho..
thats just a good reason to change out your brass conical washers every year..
if your gonna go with a LSD, then get a LSD, not a mini-slip..
