Author Topic: Anyone purchased and installed a peloquin on a 020?  (Read 8661 times)
Reply #15June 07, 2012, 02:52:26 pm
Re: Anyone purchased and installed a peloquin on a 020?
« Reply #15 on: June 07, 2012, 02:52:26 pm »
the 80% kit actually ties the spider gears together so it is closer to both axles turning at the same time.
The peloquin unit when I called the guy he said was actually a "torque amplifier" and it reroutes to the wheel with the most traction. It can be used with the 80% kit, which will help it achieve both axle spin. As is the peloquin unit will not spin both tires. If you jack up one tire and put it in gear it will only spin one...this is according to the guy selling them.
Wavetrac on the other hand is what I consider LSD and will spin both if jacked up, so be careful.
Reply #16June 07, 2012, 08:21:03 pm
« Reply #16 on: June 07, 2012, 08:21:03 pm »
you need there to be resistance on BOTH tires for a LSD to work.. if one tire has absolutely NO resistance, it wont engage internals of the locker, and it will just go thru the spiders..
if you are shooting the power to it, then both tires will spin if they have any amount of traction.
Reply #17June 10, 2012, 08:20:31 am
ToddA1
  • 434
« Reply #17 on: June 10, 2012, 08:20:31 am »
I'm thinking there may have been a communication error.  These things are ATB differentials, so although it transfers power, it never disconnects power to the slipping wheel.  When theres a low traction situation, both wheels will be spinning.  The Peloquin works on the same principle as the Quaifes.  Both brand differentials will spin both tires, but never equally.
There must be some type of difference between the two, though.  I've spoken with Gary Peloquin years ago when he first mentioned using the shim kit with his diff.  Quaife has you remove the shims.
-Todd
Reply #18June 24, 2012, 02:16:46 pm
GEE-BEE
  • 1604
« Reply #18 on: June 24, 2012, 02:16:46 pm »
I did a custom 020 from vwtransaxles.com .
FF final on a CHD with a 3.42 r&p
ext iand int were 12 pt arp bolts
powdercoated  trans housings before install
caddy is gone and I needed this setup for my torque of my build....
The new owner loves the truck , with the custom r&p it would cruise at 85 mph and still get 47 mpg
Take care to all of you here....
GB
« Last Edit: June 24, 2012, 02:19:39 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
