General Information
» Upgrades (non engine related )
View full version:
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
Installing a larger MC
tacho needle
Sunroof question
overcoming minor problems-handy dandy tool- axle nut size?
how to tear apart a VDO gauge
Can you add a "W" output to an alternator?
So, can you swap a mk2 cluster into a mk1?
Obtaining A Title
'93 mk3 brake upgrade?
non-A/C alt upgrade
2002 Passat seats into a MKII Golf??
Another combatibility question? (rear struts)
Audi Girlings G60's on an MK1?
lsd or no lsd 02a
Tachometer question.
MK2 front control arms...
deleted A/C and other things....
Body Work
max tire size for an A3
90 Jetta TD with 180mm rear Drums..can she wear 200mm?
New suspension is in! So far, so good
Rally rabbit- A1 chassis
Best way to drop my 1994 Jetta GL?
What springs and shocks are recommended for an 86 Golf??
Sweet I scored!!!....I think.
Passat/Audi A4 gearbox swop
hey Hillfolk,whatcha doin?
jumping out of gear
Automatic trannys
Cluster issues...HELP!
Electric PAS?
Benefits of 4 lug to 5 lug conversion
tranny bolt kit
MK4 seats
seam welding chassis
40% mini-slip wanted
Radio Wiring question
clutch 93 mk3 td?
( Moved to troubleshooting)
supersport 60/40 cup kit question
Door Stay Attachment
Swaybars
Quick spring question
Locks & Alarm?
wheel weight
Fitting PAS to my 1.6TD Mk2, Any 'How to's'?
Which is the best type of spring compressor?
mk2 Mexican dash differant from others?
Corrado body
mk 1 & 2 questions
