General Information
Upgrades (non engine related )
Installing a larger MC
Topic: Installing a larger MC (Read 4637 times)
August 09, 2008, 06:51:38 pm
August 09, 2008, 06:51:38 pm »
The master cylinder on my car is kaput. I can get a 22mm one cheaper then the stock 19mm one on my car currently (91 NA Golf). If I put on the larger MC, it will make my pedal harder to push correct? But moving it will move the calipers further compared to a stock setup correct? I like a firm, stiff pedal, almost like there is no vacuum assist.
Do I have this right?
August 09, 2008, 07:31:47 pm
gigaz2
August 09, 2008, 07:31:47 pm »
I've put a 23.81mm on my mk2, but also upgraded to the matching calipers (Passat vr6 with abs/eds) so, the feel is basically stock, the difference is that it stops REAL quick now.
August 09, 2008, 08:56:38 pm
cyrus #1
August 09, 2008, 08:56:38 pm »
You've got it right. Conversely, if you put on larger calipers and keep the stock MC you end up using a lot more pedal travel.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
August 10, 2008, 09:15:35 am
gigaz2
August 10, 2008, 09:15:35 am »
makes sense, so with a bigger MC and keeping the same calipers should get that hard pedal feel burn_your_money is after
August 10, 2008, 11:05:26 am
August 10, 2008, 11:05:26 am »
Perfect
Thanks everyone
August 15, 2008, 02:38:02 pm
smutts
ClackClackClackClackClack
August 15, 2008, 02:38:02 pm »
You will need to shove that pedal 34% harder, theoretically. :mrgreen:
August 20, 2008, 07:57:41 pm
foxracer1
Authorized Vendor
August 20, 2008, 07:57:41 pm »
Is there a rebuild kit avaiable for the 22mm master cyls? I have 3 but would rather rebuild them before using them.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
August 31, 2008, 07:01:37 pm
Redrum Rabbit
User+
August 31, 2008, 07:01:37 pm »
done it yet?
Feedback....
84 rabbit na and a 95 passat td wagon
Cummins 6bt swap into my 73 triple E motorhome(a project underway...)
September 01, 2008, 05:07:22 am
September 01, 2008, 05:07:22 am »
Still sitting in my backseat. Soon....
General Information
