Author Topic: Can you add a "W" output to an alternator?  (Read 4369 times)
August 17, 2008, 02:51:51 pm
red64chevelle
  • 67
« on: August 17, 2008, 02:51:51 pm »
So, I got a nifty VDO tach to be driven off the "W" terminal on my alternator, then after getting all set to install it, I find out I don't have a "W" plug.   :cry:
Can I add one to it?  Or if not, what alternator should I buy to get one.  Thanks in advance.
2003 Jetta GL TDI
1999 Beetle GLS TDI
1987 Cabby
1984 Jetta TD
1984 Rabbit GTI
1964 Malibu Convertible
Reply #1August 17, 2008, 05:15:26 pm
« Reply #1 on: August 17, 2008, 05:15:26 pm »
Yes, you just need to hook a wire up to the alt from any of the phases before it goes through the diode. On a GM alt, you can use a ring terminal on one of the studs. I'm not sure how the diodes are in a normal VW alt though. Just make sure the wire won't get caught on anything rotating and that it is well insulated.
Reply #2August 18, 2008, 04:33:51 am
gigaz2
  • 626
« Reply #2 on: August 18, 2008, 04:33:51 am »
also make it as flimsy as possible, so that it fuses instantly if something goes wrong.
