Author Topic: Automatic trannys  (Read 4640 times)
December 15, 2007, 12:59:09 am
MJF
  • 581
Automatic trannys
« on: December 15, 2007, 12:59:09 am »
First things first. I´d like to convert my Scirocco to automatic, currently I´m using 02A tranny.
I made 02A mountings to match Passat ones. So ´88-´96 Passat automatic (01M?) would be bolt on, right? Or is there big differences in drive shafts etc? Well the mounting itself is not a big deal for me, I´ll make it fit :lol:
But there is a couple bigger issues... I see from Etka, that there is ecu for transmission :(  What it needs to know? Engine speed? Throttle position? What else? Is there a possibility to convert it fully mechanic?
The second thing: Power handling... At vortex, i saw that 01M would handle 300 ft/lbs before issues arise. True or false? It is just enough to me, for now :roll:
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #1December 24, 2007, 11:10:59 am
MJF
  • 581
Automatic trannys
« Reply #1 on: December 24, 2007, 11:10:59 am »
Bump
Is there any fully mechanical overdrive automatics available?
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #2December 24, 2007, 04:34:16 pm
Automatic trannys
« Reply #2 on: December 24, 2007, 04:34:16 pm »
I wonder if you could use a newer auto out of a mk3.
Would bolt up and it has a separate ECM. would need a TPS probably.
Reply #3December 24, 2007, 05:12:33 pm
Automatic trannys
« Reply #3 on: December 24, 2007, 05:12:33 pm »
Quote from: "zukgod1"
hmmm could probably do without the TPS.  i've wondered if the tranny has a sensor for pressure.  that should allow the ecm to be controlled by pressures and shift points from RPM.  any electronics guru's??? RedRotors could probably make something work  :wink:
Reply #4April 01, 2008, 06:19:39 pm
smoken u
  • 231
Automatic trannys
« Reply #4 on: April 01, 2008, 06:19:39 pm »
yes, I belive they have a pressure sensor in them. If you use a MK 3 ECU on a Mk 2 transmission they will not work, the mk 3 uses a different harnes. '
If you do get an auto make sure to freshen it up, they are notorious for burning up the discs and converters, as well as the valve body in the pan, Because they were designed without a trans fluid filter.
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
Reply #5April 02, 2008, 02:26:25 pm
  • 1739
Automatic trannys
« Reply #5 on: April 02, 2008, 02:26:25 pm »
I don't really want to ask why, but do you really need to have a slush box.
VW never had the best in auto trannys. Unless somebody has a beef up kit to be able to handle higher loads [i.e. more reliable] i would avoid unless absoultely necessary. Maybe things have changed and or you know somebody who can rebuild them cheap???
Reply #6April 16, 2008, 05:33:58 pm
bevboyy
  • 200
Automatic trannys
« Reply #6 on: April 16, 2008, 05:33:58 pm »
Stay away from the passat autobox. Valve body failures very common. Stick to a mk2 autobox.
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #7April 17, 2008, 06:05:21 am
MJF
  • 581
Automatic trannys
« Reply #7 on: April 17, 2008, 06:05:21 am »
I´ve decided to stick with stickshift. I don´t want any ecus to my car and need od for cruising too.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #8April 22, 2008, 01:21:29 pm
hamradio
  • 282
Automatic trannys
« Reply #8 on: April 22, 2008, 01:21:29 pm »
I thought b3 passats used the 096?
I have an 096 slushbox in my b3 wagon.  Today, leaving a parking lot, it dropped out of 1st gear three times.
